Old 09-09-2010, 12:35 AM   #1
Jesse Knapp
Default 350 chevy bore size?
I am going to have my block bored, it's standard now, and wondered how much et I will sacrifice if I go .030 instead of .060. Anyone race a stocker with the .030 block then later punch out to .060? Was there a substantial gain? I don't know if there is much power in 5 extra cubic inches. Block could be used so much longer this way. Thanks in advance for any info provided.
Jesse Knapp 4899 STK, SS
Jesse Knapp is offline   Reply With Quote
Old 09-09-2010, 01:10 AM   #2
Jeff Lee
Jeff Lee's Avatar
Default Re: 350 chevy bore size?
On the great big assumption that going bigger doesn't compromise ring seal,
and if your building a Stocker that should be able to make at least 1.25 HP per CID, then you have to ask yourself is 6.25 HP worth anything to you?
Someday that extra .05- in ET may come in handy.
Jeff Lee 7494 D/S '70 AMX
Old 09-09-2010, 01:35 AM   #3
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
& think if you offset grind the crank even more inches
Old 09-09-2010, 10:11 PM   #4
Jesse Knapp
This engine would fit a class where the dp cars dominate. That's why the question. Thanks for the replies.
Old 09-09-2010, 10:19 PM   #5
Dgal
Then you will need more than 1.25 hp/ci to compete. Mebbe something closer to 1.80 hp/ci.
Dgal is offline   Reply With Quote
Old 09-09-2010, 11:26 PM   #6
Jeff Lee
Jeff Lee's Avatar
Oh...then while your at it...I would go .030" over and have microscopic EDM holes lazer applied to the cylinder walls with NOS lines flowing to these holes.
Not sure how you would plumb around the water jackets but anything is possible!
Old 09-10-2010, 12:33 AM   #7
SSDiv6
You will not sacrifice any power; you will have a gain in power. Also running a larger bore helps unshroud the valves in relation to the cylinder.
Old 09-10-2010, 07:24 PM   #8
STK1217
STK1217's Avatar
Liked 10 Times in 7 Posts
STK1217 is offline   Reply With Quote
Old 09-11-2010, 02:10 AM   #9
pro stock chuck
pro stock chuck's Avatar
Liked 53 Times in 17 Posts
Talking Re: 350 chevy bore size?
I run a low compression 350 and I can tell you that ever cubic inches is worth about 1 hp
or better and all my engines are 60 over plus So the more inches the better (that is from a pro engine shop)
pro stock chuck is offline   Reply With Quote
Old 09-11-2010, 11:50 PM   #10
Jim Hanig
Liked 99 Times in 49 Posts
Jesse if its a stock block i would stay at 030 ,if you have a bow tie then 060 the st blk will likley make more power at 030 due to cly walls are not thick enough. Jim Hanig my 2 cents
