What's the best product to use for sealing NPT threads in a fuel system? I've used both teflon tape and ARP thread sealant with good and bad results from both. Is there a better alternative? Thanks.
-Ben 3869 B/S |
I thought the ARP goop worked pretty good.
Liked 334 Times in 181 Posts
Both of those work well ya just hafta make sure ya dont get any tape over/past the threaded ends other wise it works loose and clogs up later on----Comp
Liked 99 Times in 60 Posts
take a look on the Permatex web site. You will see several choices. The one listed below has given good service.
http://www.permatex.com/products/Aut...ad_Sealant.htm |
Thank you to all who responded. I think I'll give the Permatex a try.
-Ben |
Do a search on Leak-Lok thread sealants. I've been using this product for 25 yrs. + on threaded joints on gasoline and other fuels in the automotive field w/great results. I use the Leak-lok blue. WJ
#7 | |
Liked 886 Times in 238 Posts
This stuff is the best. ...It's used by gas companies,among others. .....We just tried it on a friends model A fuel tank. ...Nothing else would seal the fuel outlet but Leak lock blue.....It's made by Highside Chemicals,Inc.......................Tom
