Old 06-09-2010, 08:42 PM   #1
Doug Domm
Liked 85 Times in 22 Posts
Default fuel cell venting
I'm installing an aluminum cell in the stocker and looking for some thoughts on venting. The cell has the rollover vent manufacturer installed. Can I use a 180 degree fitting on the rollover vent and go straight down with line or do I need a loop in the line just above the cell? Any other thoughts? Thanks Doug
Doug Domm is offline   Reply With Quote
Old 06-10-2010, 07:22 PM   #2
duster1256
duster1256's Avatar
Liked 20 Times in 3 Posts
Default Re: fuel cell venting
Mine comes out with a 90 degree elbow then straight down through the trunk.
duster1256 is offline   Reply With Quote
Old 06-11-2010, 12:41 AM   #3
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
same way mine is a 90 then down....one of those deals do what ya want
Old 06-11-2010, 08:33 AM   #4
Ed Wright
Ed Wright's Avatar
Mine goes outside the trunk (it's sitting in the tee-top storage well), then above the fuel cell, then across the car and back just in case it ended up laying one side or the other.
Ed Wright 4156 SS/JA
Old 06-11-2010, 11:11 AM   #5
Jim Craig
If you vent if anywhere under the car be sure to cover the outlet of it with a small K&N (or equivalent) filter or breather to keep "stuff" from finding its way into the cell and into your fuel system
Jim Craig is offline   Reply With Quote
