Old 03-04-2010, 01:53 PM   #1
Chad E532
Chad E532's Avatar
Liked 54 Times in 7 Posts
Question 12 Bolt Recommended Fluid Level
I have a 12 bolt with a stripped out fill plug in the stock housing so in the past I have always just added 2 quarts of fluid and called it good through the fill plug on the top of the aftermarket rear cover. But this time around when i was inspecting the inside of the housing on a fluid change it dawned on me that the cast aluminum cover probably holds additional fluid and I really do not know if I had the correct amount in there to begin with.
How much fluid should be run in this application.
I am using the Richmond Synthetic gear lube.
Thanks,
Chad
Chad E532 is offline   Reply With Quote
Old 03-04-2010, 04:45 PM   #2
Tom Goldman
Tom Goldman's Avatar
Liked 889 Times in 239 Posts
Default Re: 12 Bolt Recommended Fluid Level
I usually put in 1 1/2 to 2 quarts when using an LPW or T/A cover. .....I know guys who use only 1 quart with no problems ........If you are not experiancing any bearing problems or heat issues with the gears , I'd leave it as is. ........It's more important to be using a quality gear lube. ..........Tom
Old 03-04-2010, 10:17 PM   #3
Dragsinger
Liked 99 Times in 60 Posts
I ran 1 qt in a 12 bolt equipped as you mentioned, SBC stocker for two seasons, no problem.
Larry Woodfin 471W
Old 03-05-2010, 02:37 PM   #4
Chad E532
Chad E532's Avatar
Thanks Guys!
