Liked 503 Times in 131 Posts
Question: Is the distance between the staging lights changed for the pro runs and then back for sportsman?
At epping, there was a noticeable difference between friday and sunday. Had to creep further in to light second bulb In stock 14 of the 28 first round runs were settled a la rojo........ In no-box ET, my unofficial count was something like 7 out of 8 of the regular street footbrake class participants went down on red in round 1. Something was clearly different. The technical question part is if they changed it from 6-8 inches, can you make an adjustment in time that will save your bacon?
Eric Merryfield 1883 STK |
#2 | ||
Liked 13 Times in 9 Posts
#3 | |
Level, square, height, crown of the track, depth of the 'groove' of an older track surface (and where you stage left-to-right) are all factors. Think about your front tire, when the stage beam is (un)blocked, and how much of your tire the beam 'sees', and how it relates to your r/t's and ET's.
Liked 165 Times in 59 Posts
what is positioned height of the of the stage beams? i am currently working on reaction time as it relates to roll out gmonde
Roughly 1-5/8", but that can change depending on what stage beam height is required to come up with the right measurement on the track or sanctioning body's rollout wheel. Ironically, having the same physical rollout distance can result in wildly different reaction times, depending on the timing system. I'm not exactly certain why, but certain timing systems have certain characteristics... probably the type of photocells used, or their sensitivity settings.
Liked 362 Times in 105 Posts
A couple of years ago at the Topeka National event the tech official admitted after the fact that the roll out was changed for Saturday after the Friday night qualifying after the Pro Stock Bikes had issues with the roll out. It bit a lot of sportsman racers on Saturday when they hit the track for eliminations.
If changes are made every racer on the site should be informed not just those well connected. My 2 Cents |
The monster Kenworth Jet Truck could have something to do with it. It did blow half the foam blocks off the track. I never like racing after a jet anything.
Oh well, on to the next race! |
