Old 08-25-2009, 09:58 AM   #1
Mike Gray
Mike Gray's Avatar
Liked 705 Times in 204 Posts
Default Holley Carb Question
I found a good deal on a Holley carb with the right part number for my stocker project.
Would the carb have a problem passing tech with 2 small 3/16" holes that have been drilled through the divider plate?
Old 08-25-2009, 11:45 AM   #2
Bob Pagano
Bob Pagano's Avatar
Liked 16 Times in 11 Posts
Question Re: Holley Carb Question
Send that picture to your div. tech dir. and if he says yes print out his reply and carry it with you. I have no idea what the intent was for drilling them, anybody else ever see this ?
Bob Pagano A/SA
Bob Pagano is online now   Reply With Quote
Old 08-25-2009, 11:55 AM   #3
Bill Harris
Liked 26 Times in 13 Posts
Default Re: Holley Carb Question
You have to be pretty old to remember the purpose of those holes! Once upon a time before "double-pumpers" you could buy a kit to change vacuum secondaries to mechanical. In order to get rid of the bog, you got a special accelerator pump nozzle that directed some of the shot through two little pipes to the secondaries. Those holes were for the little pipes to pass through and squirt into the secondary barrels. Pretty lame huh?
Bill Harris
ex 2172 STK
ex 2272 S/S
Bill Harris is offline   Reply With Quote
Old 08-25-2009, 11:58 AM   #4
Rory McNeil
Many years ago there were kits available to provide some of the accelerator pump shot to go into the secondary side of vac sec Holleys via 2 small tubes that ran thru 2 holes between the air horn "wall" , just like the holes in that photo. The 2 tubes were pressed into a modified pump squirter. My guess was that so many guys didn`t think the vac secondaries were working, so they stuck a screw in the secondary slot, which would cause a major bog. These kits were a crutch to make this mickey mouse "mod" more driver friendly.
NHRA 6390 STK
M/S 85 Mustang
Old 08-25-2009, 12:02 PM   #5
Rory McNeil
Like Bill said, they were available as just the tube setup, or if you wanted to be "high tech", and didn`t want to jam a screw into the secondary slot, you could get a "gear drive" affair that fit onto the primary and secondary throttle shafts, and had a pair of 1/4 circle "gears" that made all 4 throttle blades open similtaniously.
NHRA 6390 STK
M/S 85 Mustang
Old 08-25-2009, 12:47 PM   #6
Chris1529
Liked 70 Times in 29 Posts
what is that carb going on?
Chris Bowman
The Mountain State Mustang
1984 Mustang GT350
Old 08-25-2009, 01:03 PM   #7
Mike Gray
Mike Gray's Avatar
Wow, you guys confirmed what the seller told me about the holes. (For secondary pump shot)
The carb is an 850cfm list #3418.
Regarding what it's going on, it's not an L88 '67 Vette, can anyone guess what it's for?
Now back to the question, will the holes get through tech?
I'm going to try Bob's suggestion and see what they say.
Old 08-25-2009, 01:05 PM   #8
Adger Smith
Liked 880 Times in 311 Posts
I sold a few of those secondary kits. Marketed by Eelco (sp?)
I guess that makes me in the really old, right Bill? :~)
If tech didn't like them fill with a little epoxy or JB weld.
Adger Smith (Former SS)
Old 08-25-2009, 04:12 PM   #9
Bub Whitaker
Yes ur old... installed that kit on my L79 66 Chevy II...
Bub Whitaker
Bub Whitaker is offline   Reply With Quote
Old 08-26-2009, 07:35 AM   #10
BlueOval Ralph
Banned
Still have one in my old Holley parts, the gear drive and the squirter Y
BlueOval Ralph is offline   Reply With Quote
