Old 04-06-2009, 06:25 PM   #11
CrateCamaro
CrateCamaro's Avatar
Liked 19 Times in 7 Posts
Default Re: sherman lifter help
I had the same trouble. As you bumping the motor over the things building pressure and pumping up the lifters. "Set it like a solid" now becomes pretty hard when things are moving around. I got mad and started setting them at .010 and or .015. When you run the motor over 3-4 revolutions it would close up and have like .005. Loose or tight did nothing for ET at all for me anyways. But im running another set this year and will be "setting them like a solid" again.
Tony Valerio 1968 Camaro
1700 IHRA H/CM
1701 NHRA SS/?A
Old 04-06-2009, 08:15 PM   #12
partsbob67
Liked 79 Times in 11 Posts
plenty of clearance between the rocker and spring. running behives.i got some top secret help with these so i'm going to try his way. on question i have is wouldn't you be able to adjust them according to the firing order? or does the cam duration make that not a good way to do that?
bob beals 7244
partsbob67 is offline   Reply With Quote
Old 04-06-2009, 08:17 PM   #13
JHeath
JHeath's Avatar
Liked 370 Times in 101 Posts
I always adjusted mine by firing order.
Jerry Heath
I/S '93 Cobra
FS/J 2010 Mustang "Ebay CJ"
Old 04-06-2009, 09:11 PM   #14
Robert Simpson
Liked 20 Times in 12 Posts
Smile Re: sherman lifter help
I run sbc hyd shubecks. I have never used Sherman's lifters I take they are adjusted just like Shubeck's? How do you compare the two? Which do you guys prefer? Last does Sherman have a web site or a contact number?
Robert Simpson is offline   Reply With Quote
Old 04-06-2009, 09:22 PM   #15
partsbob67
shermanracing@bellsouth.net
bob beals 7244
Old 04-06-2009, 09:55 PM   #16
Alan Warman
I know I am going to sound stupid for asking this but what does EOIC mean.
Alan Warman
STK 4107
Alan Warman is offline   Reply With Quote
Old 04-06-2009, 10:57 PM   #17
JRyan
Liked 112 Times in 31 Posts
Alan,
When the Exhaust starts to open (EO), adjust the intake lash. When the Intake valve closes (IC), adjust the exhaust valve. Some people prefer firing order, others prefer EOIC. Either way works if you're consistent, although some people will swear that one or the other gained them mucho HP.
Jerry
Old 04-07-2009, 09:32 AM   #18
Darrin Christen
Darrin Christen's Avatar
Question Re: sherman lifter help
Jerry, Do you adjust the exhaust valve when the intake just starts to close or when it is fully closed? I do the exhaust when the intake just starts to close, is this correct?
4878 SS/GA 66CHEVY II
Darrin Christen is offline   Reply With Quote
Old 04-07-2009, 10:44 AM   #19
Evan Smith
Liked 115 Times in 5 Posts
Bob,
I've had great luck with these lifters, call me if you have any more questions. 201-376-3069.
Evan
Evan Smith 1798 STK
Evan Smith is offline   Reply With Quote
Old 04-07-2009, 08:43 PM   #20
Robert Simpson
Thumbs up Re: sherman lifter help
Bob, thanks for the contact. How do these lifters compare to shubecks in a traditional hyd. flat tappet? Can you run the same seat pressure? Can you use the same set from cam to cam? Thanks for the info.
