Old 07-21-2008, 08:17 PM   #1
Wade_Owens
Wade_Owens's Avatar
Liked 3 Times in 1 Post
Default Generator Help.....
I have a Honda Black Max generator that I mounted in the bed of my truck. I also have an additional fuel tank mounted that I want to feed the gen off of. Is there a low pressure fuel pump I can use to feed the small carb.
Anybody doing this or have a better idea?
Wade O
Old 07-21-2008, 08:36 PM   #2
Ed Fernandez
Ed Fernandez's Avatar
Liked 100 Times in 45 Posts
Question Re: Generator Help.....
Aren't portable generators all gravity fed?
Ed F.
Former NHRA #1945
Former IHRA #1945
T/SA
Old 07-21-2008, 08:52 PM   #3
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
Default Re: Generator Help.....
Ed is correct...most small portables have the fuel tank above the carb. and use gravity to feed the carb. Facet makes low pressure pumps that are 12 volt and that is the types that are used on Onan's and others that pull fuel from another tank. Those pumps are readily available at many auto parts stores and other suppliers. Pressure is about 2-4 lbs. You have to have it hooked to the battery and only running when the generator is running and you will need some sort of battery charging to keep the battery from going down. RV type units like an Onan have this all included in the design......
Rich Biebel
S/C 1479
Stock 147R
Old 07-22-2008, 10:15 AM   #4
Wade_Owens
Wade_Owens's Avatar
I have an intank fuel pump (4-6 lbs) mounted inside the "L" tank to supply my stock tank. The generator's carb is mostly above the fuel level, so, I need some sort of low pressure pump to supply it with flooding it out. I know this may not be the ideal situation, but, I need to make it work for now.
Thanks for any input.....
Wade
