Old 07-21-2008, 08:08 PM   #1
Wade_Owens
Wade_Owens's Avatar
Liked 3 Times in 1 Post
Default Synthetic Auto Trans Fluid....
what are the pro's and con's of using it. Some say it cant be used in a pg, is this true?
Any help appreciated.....
Wade O
Old 07-21-2008, 09:07 PM   #2
Brian Hansbury
Brian Hansbury's Avatar
Send a message via Yahoo to Brian Hansbury
Default Re: Synthetic Auto Trans Fluid....
hey it can be used in a power glide i have two cars myself and 7 more i race with been using it for a year i am a bg distributer and it is a group five base stock one of the purist lower temp by 20 degrees
Brian Hansbury is offline   Reply With Quote
Old 07-21-2008, 09:24 PM   #3
Liked 1,821 Times in 413 Posts
Wade, the type of fluid required is determined by the type of friction materials used. Modern friction materials are compatible with synthetic fluids. Type F fluid will normally still give a more "positive" shift.
Old 07-21-2008, 10:36 PM   #4
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Wade use the type F as you should know PG's love temp! If your not going to the water box with 150 degrees of temp in the trans your leaving ET back @ the trailer! p.s. it's the only thing I don't use synthetic in.
Old 07-21-2008, 11:05 PM   #5
Adger Smith
Liked 880 Times in 311 Posts
Try the Royal Purple. I had a buddy that helped with some of the development of it & I tested some in P/G's. The way I understand it they have reduced the friction modifyers to make better clutch lock up. I found it made all the roller bearings I was installing in P/G's last longer than Type "F". Never saw any clutch or steel wear or burning, either.
Adger Smith (Former SS)
Old 07-25-2008, 04:29 PM   #6
ron mattson
Liked 67 Times in 30 Posts
amsoil also has a very good product called supershift,it also has a very low amount of friction
modifiers and makes things run cooler.
ron mattson is offline   Reply With Quote
Old 07-25-2008, 06:18 PM   #7
Myron Piatek
Liked 138 Times in 51 Posts
Thumbs up Re: Synthetic Auto Trans Fluid....
I'll second the Amsoil Supershift recommendation. My 904 trans lasts for years and much less "debris" compared to conventional fluids. Synthetics hold up to heat much better than regular oils and heat is the primary problem-causer in automatics.
Amsoil source & info:
www.thelubepage.com
LOCOMOTION Racing
Old 07-25-2008, 09:55 PM   #8
Wade_Owens
Wade_Owens's Avatar
Thanks to all who responded....
Wade
Old 07-30-2008, 12:15 PM   #9
SSMA 3838
Synergyn makes a very good product also. Super Shift ATF.
www.synergynracing.com
SSMA 3838 is offline   Reply With Quote
Old 07-30-2008, 07:23 PM   #10
art leong
I'm using Mobil one synthetic.
Has anyone got a "yea" or "nay" ?
Art Leong 2095 SS
