#31 |
Liked 1,173 Times in 333 Posts
Pardon my ignorance, but what do you mean by 1 lb breaks? Does that mean instead of 14, 14.5, 15 lb/hp it would just be 14 and 15 lb/hp? I can see how that would simplify Stock and cut the number of classes in half. It'd suck for me, but would make the class even more performance oriented. Be a blast to watch, but not so fun to race.
Dawson Pauley #2827 N/SA 1980 Malibu SW 2S 305/180 #2827 S/ST 1978 Mazda RX7 w/ 383 sbc/glide |
#32 | |
Liked 489 Times in 227 Posts
Jake Biermann |
#33 |
Liked 1,342 Times in 409 Posts
There were way more car brand battles that made fastest car in class fun. No driver weight was in play in the early days. Those battles for the new generation vehicles and the folks that relate to them are only available at E.T. races now.
Paul H |
#34 |
Liked 460 Times in 59 Posts
1 lb. breaks get tougher at higher HP ratings. At 200 hp a racer could easily bounce between 2 classes. At 400+ HP a racer could be stuck, and there are several combinations in the 500-650 HP range.
#35 | |
Liked 7,730 Times in 1,739 Posts
Different deal but just an FYI because I've run into it, some of the FWD stuff is 3 lb. breaks. Imagine what it's like with a 140 HP combo having to add or subtract 420 lbs.. It kinda makes a combo a 1 class car in a hurry.
#36 |
Liked 337 Times in 46 Posts
Billy all the rear wheel drive cars I ever raced had a natural class.
I don?t know when it became fashionable to go up a class and down a class. If everyone was forced to run their natural class more heads up would result. The AHFS would have a better chance to work if that is what racers want. Forgive me if it doesn?t work for FW drive cars because I don?t have any idea how they work.
Jim Marshall 1967 STK |
#37 |
Liked 334 Times in 185 Posts
It wasn't. 02-.03 it was .200-.300 (2 or 3 tenths, not hundredths).
Gary Lucier - 7832 STK. / 7832 E.T. EF/S Slow Sled. I am, but a simple test of your true patience. So, do all the really "Big Wheelies" you can! |
#38 |
If there is not a class for you there, they will make 1 up. But, they face but at the end of each day Comp has the same issues as far as indexes. And a cure, personal permanent and immediate personal index hits. Watch the class closely as 1,000 ft drops are common among fearful yet very competitive racers.
The expensive hobby is not for the meek and you better run it like a real business or broke even the rich will be.
Gary Lucier - 7832 STK. / 7832 E.T. EF/S Slow Sled. I am, but a simple test of your true patience. So, do all the really "Big Wheelies" you can! Last edited by Cglrcng; 11-21-2024 at 04:10 PM. Reason: Additional words added |
#39 | |
And extra 150lbs that tacks on in both classes.. Billy sees all the pros and cons.. They call it reality and it sucks.
#40 | |
Then over time the combined FWD classes and got rid of GF-and FF recently. EF now bottom class at same 17.45 sea level index. (But added 6hp). Imagine you run a G/SA car and one day you wake up and you are magically put into E/SA, and then they also tack on 6.5 percent more HP onto your combo. You would run up a class also at least until you could make both the weight and the E.T. index to get it down to natural DF/S class (the car was never that light the day it drove off the assembly line), It took a ton of work to shave off 345lbs. And do it by the book. It happened, but reality bites because it wasn't a full second faster...yet. Putting the weight back on was a necessary evil. Parts removed went right back on in a day. 2/10ths above index was 2/10s below index at same high elevation track and down 1 class in EF/S I sit. Flogging away spending time and effort to get it to run at elevation what it is proven capable of running at sea level. We do what we must,, heads up or shoe polish driving against much faster dance partners at the stripe. And I prefer both. But the faster the partner in the other lane is the most fun of all.
