Old 08-07-2024, 03:27 PM   #1
68Coupe
Default Help with a Ford Maverick
Looking for some ford experts to help out. We have a 72 maverick suppose to be a 5 lug car from the factory.
We bought new front drums for a 72 Maverick but the don't fit.
the center hole on the drum is just a little under 2.5"
the center of the hub that the hole has to fit over is just a little over 2.75"
did someone change these hubs a some point, if so anyone have any idea what the may have come off of.
there are 4 different sets of numbers on back of the hub, is there anyway to look them up and see what it is.
68Coupe is offline   Reply With Quote
Old 08-07-2024, 05:46 PM   #2
Charles Stewart
Liked 753 Times in 213 Posts
Default Re: Help with a Ford Maverick
From what I see, all engine options for the 72 Maverick have a drum and hub center hole of 2,43 in.
Look like the 1974 and up Maverick with the new legislation front bumber have a 2,78 in. front center hole for drum and hub.
Hope this will help,
Charles Stewart is offline   Reply With Quote
Old 08-08-2024, 02:07 PM   #3
68Coupe
so maybe someone change hubs at some point and now it has 74 or later on it
Old 08-08-2024, 11:18 PM   #4
Rory McNeil
Liked 1,074 Times in 294 Posts
Mavericks with either the 250 cube 6 cylinder, and the 302 V8s had 5 lug wheels, the smaller (170 and 200 cube) 6s were 4 lug. Are you trying to replace just the outer drum, and reuse the old hubs? If so, I have never seen a factory Ford front brake drum that had a seperate drum and hub, unlike older drum brake GMs, on the Fords, the drum and hub are 1 piece, the hub is not meant to be removed from the drum.
NHRA 6390 STK
M/S 85 Mustang
