Old 12-06-2023, 01:30 PM   #21
Mark Ugrich
Liked 71 Times in 38 Posts
Default Re: Ford 302 SS build
Originally Posted by ShipC1970 View Post
Gotcha so if I run a 390 combo I could run in GT since the 390 wasn’t offered in the 70 mustang? What about a 68 302 then? I couldn’t run it in GT since the 302 was offered in the 70 mustang?
Yes you can run the 68 302 in SS/GT. I think you want a J code 302.I believe that engine allows a holley four barrel.
Old 12-06-2023, 01:34 PM   #22
ShipC1970
Liked 28 Times in 11 Posts
Would I have to find a J code long block? Or could I just use a 68 block with the 70 heads? Or? Sorry all new to me!
ShipC1970 is offline   Reply With Quote
Old 12-06-2023, 01:39 PM   #23
Mark Ugrich
No, you claim the engine as a j code and must adhere to the specifications for that engine. The people in tech check to make sure you’re legal, if they check.
Old 12-06-2023, 01:43 PM   #24
ShipC1970
Ok thanks for the clarification i appreciate it! I’m just torn between running a 302 or a 390. Car is already set up for 302 and I don’t really feel like going through the troubles for big block swap.
Old 12-06-2023, 03:43 PM   #25
James Hill
Liked 10 Times in 4 Posts
You can't get the Edlebrock Aluminum heads for the 390 any more so that combination would be out for me. The iron 68 heads are hard to find, but it's a good combo. The aluminum head 302 is easy to source parts. 64 289 rated at 203 is a good combo also. Your going to buy rods and pistons anyway, getting a stock crank done (from Castillo Crankshaft service which is near you) at a reasonable price.
James Hill is offline   Reply With Quote
Old 12-06-2023, 03:44 PM   #26
B/S 428
Liked 154 Times in 34 Posts
There's a reason no one is running the 69/70 302 2bbl combo, the HP is 220, the carb is 1.08 venturi rated at 287 cfm, jmo I looked at doing this years ago and my math says you'd be lucky to run the index.. however the 68 302 rated at 207 with 68 cast iron heads, 4bbl Holley, GT SS is a much better choice..Brian Seaberg 627
B/S 428 is offline   Reply With Quote
Old 12-06-2023, 09:04 PM   #27
Liked 5,121 Times in 1,952 Posts
Wink Re: Ford 302 SS build
64-65 352 4 bbl
Old 12-06-2023, 09:25 PM   #28
GTX JOHN
Liked 2,484 Times in 697 Posts
Castillo is in the process of retiring due to Health Issues.
John Irving
741 Stock
741 Super Stock
Old 12-07-2023, 11:02 PM   #29
goinbroke2
Liked 391 Times in 153 Posts
Originally Posted by 1347 View Post
even 351w are good combos to research also.
What 351w would be able to make any power? Even the rare D0 heads flow same/less than gt40P's. They barely support a 302 let alone 351 inches.
Reminds me when Ernie Elliot built a 327" for restrictor races and qualified WAY WAY quicker, so nascar made the "minimum cu in" ruling.
What secret am I missing where a top end that is barely enough to feed 300 cubes will run in a performance category with 50 more cubes?
Edit: On Stan's site I checked out the basic heads from ford/chev/dodge.
Mopar 051 head 1.88/1.60 (no idea if its good or bad)
50/49 113/97 165/123 188/123 193/137
Chev 462 1.94/1.50 (again no idea if this is a good head or not)
50/54 119/88 167/116 198/128 212/134
Ford E7 (as good as any and better than most stock ford heads) 1.78/1.45
52/39 95/74 132/98 143/104 159/109
To me, ford heads barely flow enough for 302's and once you see what 360's and 350's have for "base" heads, the 351W to me is way under headed.
Richard Holdener ran a stock junkyard 302 and got 259hp and a stock 351 got the same but at a lower rpm which to me says as cast, stock heads will flow enough to produce 260hp and that's it. (for a base to start from)
Am I reading something wrong??
Old 12-07-2023, 11:23 PM   #30
B/S 428
I looked at the 69/70 351w combo because I have several mustangs, once again there's a reason no one that I know of is running this combo rated at 290 HP, I wanted to run it years ago because 69s are way cool but after doing the math I put it on hold, the rated HP is to high so I did a street bracket build instead..Brian Seaberg 627
