Old 11-25-2023, 12:30 PM   #11
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Default Re: Wanted suggestions how to create low drag Wilwood brake
Bracket and class racing, I do
Old 11-25-2023, 01:10 PM   #12
Ron Miller
Liked 13 Times in 7 Posts
Originally Posted by 1320racer View Post
you buy Mark Williams brakes.
I was a Poor Boy when I built this car. Today I'm $till a Poor Boy.
Ron Miller is offline   Reply With Quote
Old 11-25-2023, 01:17 PM   #13
1320racer
1320racer's Avatar
You ain’t a poor boy if you race. You maybe be a cheap boy though
Old 11-25-2023, 02:18 PM   #14
340Cuda
Liked 800 Times in 337 Posts
Other than the front wheels turning during wheelstands have you folks with the low drag brakes seen any real improvements in ET?
Thanks,
Bill
Old 11-25-2023, 07:12 PM   #15
SSDiv6
Liked 1,577 Times in 581 Posts
Originally Posted by Ron Miller View Post
Guys,
I'm looking for suggestions on how to create low drag brakes. I have Wilwood 4 piston caliper brakes front & rear on my Gen 3 GT/DA 92 Camaro. Is there a kit one can buy? The TDM brakes are out of the question.
Thanks for looking,
For the hub, use the DRP front bearings, with their spacers and low drag seals. You will be a big surprise.
https://www.drpperformance.net/hub-c...0car%20around.
Old 11-25-2023, 09:02 PM   #16
Ron Miller
SSDiv6,
Thanks, I was looking for that earlier. And their direct site is a pain to navigate.
Old 11-25-2023, 09:23 PM   #17
Ron Miller
Honest Ed,
I wouldn't ***** 💩 you. I'm a POOR BOY. I haven't race my MPR 92 Camaro in 27 years. My car has only 20 to 25 runs on it. It still has the New Race Car Smell. I parked it when I got married in 97 and started my Family. So, with a little Luck and a few dollars. I might get a chance to race next year. And make some improvements.
ID:	69032   Click image for larger version
Old 11-25-2023, 10:51 PM   #18
SSDiv6
SSDiv6,
Hi Ron,
The bearing kit is P/N 10585BR
The spacer is P/N 10521s
The seal is P/N 10577
Get also their low-drag bearing grease.
Call them.
They are some of the nicest people to deal with.
This is a link to their catalog.
https://www.drpperformance.net/_file...e3d1889264.pdf
Old 11-27-2023, 02:26 PM   #19
Dirk Olson
Liked 172 Times in 46 Posts
Changing the square ring to a round ring helps. Still not Lamp but it is better. Then install low drag bearings with spacers. Remember when doing all this, it is pepper in in the fly sh.t stuff but all is worth something in the end.
Dirk
Dirk Olson 5036 STK
Dirk Olson is offline   Reply With Quote
Old 11-27-2023, 04:19 PM   #20
Mike Pearson
Mike Pearson's Avatar
Liked 1,919 Times in 576 Posts
Pull your brake pads off and check them to see if they are worn on a skew. I checked mine with a vernier caliper and found they were worn on a skew. I ground them flat again with a right angle grinder. That stopped the dragging. If you are too heavy on the brake pedal it will wear the pads unevenly and they will drag like crazy. You have to be real easy on the pedal with light weight brakes.
Mike Pearson 2485 SS
