#31 | |
Liked 1,583 Times in 582 Posts
#32 | |
Liked 734 Times in 385 Posts
Been there done that. ![]() Stan |
#33 |
Liked 880 Times in 311 Posts
-Head A stock completly untouched
-Head B has flow characteristics that make me feel like it will be okay (.5 under) -Head C has flow characteristics the make it a record setter IMHO And Head C has correct port volume, but probably has a larger CSA at several key places in the port.
Adger Smith (Former SS) |
#34 |
Liked 302 Times in 73 Posts
Let me add a little more specific question to this:
.444 valve lift cam. Lift -------- Head A -------------- Head B .050 -------- 50.8 -------------- 35.1 .100 -------- 81.0 -------------- 57.6 .150 -------- 108 --------------- 88.2 .200 -------- 129.9 ------------ 117.12 .250 -------- 142.3 ------------ 136.6 .300 -------- 157.0 ------------ 158.0 .350 -------- 161.8 ------------ 172.6 .400 -------- 166.8 ------------ 175.6 .450 --------- 166.4 ----------- 175.6 .500---------- 165.8 ----------- 174.5 Which head would you rather have? Head B is a bit better up top but Head A is substantially better down low. I would still say looking at it from an area under curve stand point that Head B would be slightly larger but very small difference. Last edited by HawkBrosMav; 12-14-2020 at 02:11 PM. |
#35 |
Liked 7,732 Times in 1,739 Posts
Low-lift flow is very important in a "restricted" engine.
#36 | |
#37 |
Liked 333 Times in 180 Posts
exhaust port flow is going to come into play in this too
#38 |
Liked 73 Times in 36 Posts
When doing comparative testing, it is imperative to use the same radius inlet guide (not rolled up clay method) as the specific entry has influence on results. On the exhaust side, one should always use a short length of pipe for the same reason.
The methodology of area under the curve is best evaluated by graphics and using the cfm/sq in rating. One should have a graph of the cam / valve lift for that evaluation as well. It is in these types of details that gains are sqeezed out of otherwise run of the mill components. After the heads are evaluated, then one can begin sorting out manifolds and carbs and placement of same. Notes, lots of notes so you can take a look at what items worked the best. This is particularly important when you are evaluating valve jobs. Lots of patience, study, and thoughts with coffee will help get the job done. ![]() Regards, HB2 ![]() Dissident |
#39 | |
I get that, but would you run a set of heads you knew flowed less air intentionally knowing the TB and intake may be a restriction larger than the heads or would you put the "best" flowing heads on regardless? I think I'm more curious as to what people are more concerned with if area under the curve is similar between 2 sets of heads. Having the larger peak numbers or giving up a little up top to have much better down low numbers. Obviously there are other factors to consider... mainly possible restrictions before the port and then the relation to exhaust port flow as mentioned in the next reply. But at this point for a simplistic questions and answer.. would you prefer a head that peak flows more or flows down low more given the overall "area under the flow curve" is generally equal. Billy seems to lean towards low flow potentially with his response. |
#40 | |
