Old 08-10-2020, 07:15 PM   #1
racer913
Default M/T PRO BRACKET radials
has anyone used rim screws with these slicks? I Know it says do not use rim screws but...
racer913 is offline   Reply With Quote
Old 08-10-2020, 11:10 PM   #2
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
Default Re: M/T PRO BRACKET radials
20-25 years ago I was putting screws in Hoosier radials with no problems.
When I went from 8" wheels to 10" wheels I didn't want to drill them, so I stopped using screws. Haven't noticed any reason to go back to it.
S/ST 51
S/C 53
Old 08-10-2020, 11:37 PM   #3
Stephen & Horace Johnson
Liked 161 Times in 52 Posts
I raced at a local heads up race this past weekend and saw many cars running this tire and no screws....
Stephen Johnson #2162
Horace Johnson #2167
Stephen & Horace Johnson is offline   Reply With Quote
Old 08-11-2020, 07:26 AM   #4
nssracer
Liked 207 Times in 23 Posts
I run them on my DragnWagn NSS car....no screws....amazing tire.
Old 08-11-2020, 10:37 AM   #5
340Cuda
Liked 801 Times in 338 Posts
My son runs them on his Drag Week 1968 Barracuda. It runs 10.50s @ 3,500lbs. He runs no screws in them with no problems. I think he normally runs them at about 17psi.
Old 08-11-2020, 11:06 AM   #6
8secchevelle
Liked 6 Times in 2 Posts
I’m on my 3rd season with the 10.5x29.5 on a 3500lb nostalgia super stock chevelle on a 9.75 index it has 60 footed 1.31 with a 1.360 restrictor plate , I do not use screws but do use permatex hi tack on bead , be sure and do that the first set did not move on the wheels but 2nd set did so they was broke down and hi tack applied and no more slipping . I have seen pictures of radials used with screws with destroyed beads but no personal experience.
8secchevelle is offline   Reply With Quote
Old 08-11-2020, 11:49 AM   #7
Dave Gantz
Liked 251 Times in 125 Posts
I would try it without screws, glues, or other tricks. If it works, you've eliminated more "stuff to be done". K.I.S.S.
Old 08-11-2020, 12:42 PM   #8
pmrphil
Liked 347 Times in 151 Posts
Just make sure to use only water, not any kind of lube or soap when mounting.
Phil Molski
PMR Performance
S/C 1623
Old 08-11-2020, 08:14 PM   #9
jmantle
Liked 172 Times in 81 Posts
I was told by MT no screws with radials. I run 26 x 8 MT's, no screws, no problems, admittedly limited HP but 3500 lbs.
Jim Mantle V/SA 6632
jmantle is offline   Reply With Quote
Old 08-12-2020, 07:45 AM   #10
Todd Geisler
Liked 345 Times in 149 Posts
Been running radials for 25+ years now. Clean the rim bead seat surface well, no lube and install dry.
Faster cars may want to install beadlocks, but I have been 1.12 60' without.
Radial beads are not designed for screws. Friend and customer had a bead split around the circumference totally destroying the tire from rim screws.
Todd Geisler is offline   Reply With Quote
