Old 07-11-2020, 11:36 PM   #11
Willyracer
Willyracer's Avatar
Liked 57 Times in 24 Posts
Default Re: Hoosier radial drag slick
Originally Posted by Glenn Briglio View Post
Light weight or standard radial?
They are the lightweight radials
Willyracer is offline   Reply With Quote
Old 07-12-2020, 10:05 AM   #12
ken robinson
Liked 215 Times in 86 Posts
On an A/SA car c06 wont last as long as c07 , but an A car gets less tire life in general compaired to my E car , I do 2 to 3RD gear burn out count to 5 and drive out , 20psi . What rear shocks and settings and do you hit a wheelie bar like most A/SA cars ?
Old 07-14-2020, 11:37 AM   #13
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
I run the C07 tire at 17 psi on a 10" rim and get at least 150 passes. I don't use the line lock at all on the burnout. 1-2 and out. Car is 3600 lbs, 1.41 - 10.20.
I experimented with Goodyears for a bit but I've generally run this same combination on Hoosier radials since 1995.
S/ST 51
S/C 53
Old 07-14-2020, 12:02 PM   #14
Glenn Briglio
Glenn Briglio's Avatar
Liked 971 Times in 308 Posts
You should be using more than 15 lbs air pressure
Old 07-14-2020, 03:14 PM   #15
Willyracer
Willyracer's Avatar
we run 20.5 psi
never tried going up or down from there
always heard 17 to 21 without much
different to 60 ft time
Old 07-14-2020, 03:51 PM   #16
Lenny5160
Lenny5160's Avatar
we run 20.5 psi
I've run 16-26 and the car runs the same. I've gone lower on psi trying to get them to wear evenly, but I still wear the centers out first. I usually only check them before the first and second runs of the day because it really doesn't seem to matter.
A couple times I have waited too long to replace them and when these tires are done, they are DONE and will not hook at all.
S/ST 51
S/C 53
Old 07-14-2020, 04:29 PM   #17
Glenn Briglio
we run 20.5 psi
My bad wrong thread
Old 07-14-2020, 09:32 PM   #18
B Parker
Liked 2,336 Times in 464 Posts
Willy If you are getting close to 40 passes on a set of lightweights you have done well. You are running A/SA with a big block Chevy not only will it eat tires but it also likes the taste of money. Not sure why you put a set of lightweights on. Buy the regular ones and you will get 50 plus runs on them. BP
Old 07-15-2020, 12:22 PM   #19
Lenny5160
Lenny5160's Avatar
Originally Posted by B Parker View Post
Lenny If you are getting close to 40 passes on a set of lightweights you have done well. You are running A/SA with a big block Chevy not only will it eat tires but it also likes the taste of money. Not sure why you put a set of lightweights on. Buy the regular ones and you will get 50 plus runs on them. BP
I think you're addressing the wrong guy. I've never run the lightweights specifically because I'm trying to maximize the life on my heavy, small-tire BBC bracket/Super Street car. I wouldn't run anything other than radials though.
S/ST 51
S/C 53
