Old 01-20-2018, 12:38 PM   #1
3 window
Liked 3 Times in 2 Posts
Default Bent Landrum spring
I’ve got a set of Caltracs on my ‘70 Nova with Landrum monoleafs. The right rear spring is bent, I’m guessing from the force applied by the Caltrac bar. Is anyone running doin anything to strengthen the Landrum (extra top half for example) or just running Calvert split monos? Thanks guys.
3 window is offline   Reply With Quote
Old 01-20-2018, 12:44 PM   #2
Joe Martens
Joe Martens's Avatar
Liked 196 Times in 69 Posts
Default Re: Bent Landrum spring
Calvert split monos!
Joe Martens AA/Stock 3969
Joe Martens is offline   Reply With Quote
Old 01-20-2018, 02:45 PM   #3
Liked 10,702 Times in 2,228 Posts
What is bent? Front or rear segment and has ride height changed? You might be able to add a half leaf.
Old 01-20-2018, 03:10 PM   #4
3 window
The Landrums are a parabolic monoleaf. The front of the spring is bent. Yes it changed the ride height.
Old 01-20-2018, 04:48 PM   #5
GTX JOHN
Liked 2,483 Times in 697 Posts
I have a dozen cars with John's springs and shocks.
A couple are Heavy and have over 500 runs on them
in last ten years and we have not noticed any issues.
We adjust them accorded to his directions and make sure that nothing
is binding and everything is free moving. Perhaps the geometry on the spring you are
using is not compatible....We bought a car with Mopar Superstock springs
and Calvert bars and it was so bound up that it may as well been mounted
solid!
I have never tried them without his springs or driven them extensively
on the street.
His stuff is the best things we have every used on suspension......Use his Shocks/Struts
and other suspension pieces as well.
John Irving
741 Stock
741 Super Stock
Old 01-20-2018, 05:35 PM   #6
Might be able to press it back to correct ride height, then add half leaf of same curve. I agree with John everything needs to move freely.
A four wheel scale will tell you a lot.
Good luck
Old 01-20-2018, 08:23 PM   #7
Painter
Liked 162 Times in 45 Posts
I have run the Landrum springs forever with no problem and no extra leaves. If you bent a spring I would think something is bound up or way out of adjustment.
Painter is offline   Reply With Quote
Old 01-25-2018, 08:03 PM   #8
Casey Miles
Liked 499 Times in 91 Posts
Look into a company called Flex Form, they have composite springs. About 8 lbs a side and are around $400.
