Old 01-08-2018, 02:13 PM   #1
R5ROB
R5ROB's Avatar
Default V10 viper / 727 combo help
Looking for suggestions on who could help out on getting parts to put a 727 behind a viper v10
Contacted ati with no luck they only make a adapter plate to bolt a gm trans on it
Car will be in gt so I can’t run a glide or 400
Any help would be greatly appreciated
R5ROB is offline   Reply With Quote
Old 01-08-2018, 03:08 PM   #2
jmcarter
jmcarter's Avatar
Liked 3,179 Times in 972 Posts
Default Re: V10 viper / 727 combo help
Contact Kevin Helms, he’s built one or two of them.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 01-09-2018, 08:09 AM   #3
Liked 10,711 Times in 2,230 Posts
I think first V10's were glide cars. Dave at Pro Trans
Old 01-10-2018, 12:11 AM   #4
R5ROB
R5ROB's Avatar
Found a 727 that will work that came in the trucks for a couple years before they went to the 518 that all my good parts will work in
On the classracerinfo site it only gives hp rating with a stick at 450 hp no auto listed for the 97 488 v10
So Would it be rated the same with auto ?
Old 01-10-2018, 04:44 AM   #5
GTX JOHN
Liked 2,485 Times in 697 Posts
I do not recall any year Viper ever coming with Auto = Therefore NOT legal
for stock class if that what you were planning.
John Irving
741 Stock
741 Super Stock
Old 01-10-2018, 10:46 AM   #6
R5ROB
R5ROB's Avatar
Car is a super stock gt fwd conversion
Old 01-10-2018, 01:25 PM   #7
Tim Kish
Liked 11 Times in 4 Posts
I'm intrigued. What FWD conversion chassis, with the lack of firewall relief for any Mopar RWD conversions, does a V10 fit in? Bellhousing adapter wise I though the V10 was the same bolt pattern as a small block but a little research it appears same as the Cummins instead.
Tim Kish
3032 SS/GS
Tim Kish is offline   Reply With Quote
Old 01-10-2018, 04:19 PM   #8
Bob Bender
Bob Bender's Avatar
Liked 459 Times in 90 Posts
Please call Dave Collette 443-807-1569
Bob Bender 144 O/SA
Old 01-10-2018, 05:01 PM   #9
Jeff Teuton
Liked 325 Times in 50 Posts
Depends what year motor you are looking at. The 488 bolt pattern will fit a 727 Early Diesel T/Flite I have two cases for that combo. Also depends how you plan on starting it. The later DP with the 513 motor has an an adapter for a GM Glide or T350 and both have different starting methods. Calll me @ 985-804-6161. I have a Viper with a t/f here that is for sale, and I had another. And can probably help you. Jeff Teuton or email jefft@southlanddodge.com
Jeff Teuton 4022 STK
Old 01-10-2018, 07:29 PM   #10
R5ROB
R5ROB's Avatar
Thanks guys Got the trans covered now after talking with Jeff that has already done this
