Old 10-08-2017, 08:10 PM   #1
Nmbr1GMfan
Default Q-jet ID
Anyone recognize this builder?
Todd Greene
Old 10-08-2017, 08:30 PM   #2
MR DERBY CITY
Liked 7,938 Times in 1,519 Posts
Default Re: Q-jet ID
Scott Welborn from SC worked on quite a few Q jets years ago...
Old 10-08-2017, 08:45 PM   #3
PJ305
Liked 5 Times in 4 Posts
Your car being from D-1 I would say Joe Scott
PJ305 is offline   Reply With Quote
Old 10-08-2017, 08:50 PM   #4
Wayne Ewing
Could be Joe Scott from northern Pa
Wayne Ewing is offline   Reply With Quote
Old 10-08-2017, 09:25 PM   #5
Nmbr1GMfan
Thanks guys.
Todd Greene
Old 10-08-2017, 09:38 PM   #6
Dissident
Liked 73 Times in 36 Posts
Look on the bottom of the throttle plate - If a Joe Scott piece, will be vibra penciled with Scott on the bottom and also the rear (with a number). Last one I worked on was #72 (that was probably at least 30+ yrs old) and also had a brazed secondary lever so all four throttle blades opened at the same time.
Regards,
Dissident
Dissident is offline   Reply With Quote
Old 10-08-2017, 09:56 PM   #7
Nmbr1GMfan
Regards,
Dissident
Thanks I'll check when it comes off. Don't think it's been apart in a while, seems ok WOT but loads up at idle a bit. I'll go through it or send it to someone.
Todd Greene
Old 10-08-2017, 10:09 PM   #8
Nmbr1GMfan
Also as an addendum, no the fuel system is probably not ideal (blue pump and holley regulator, deadhead) but the pressure is turned down to 5 to eliminate that as the rich condition.
Todd Greene
