Old 12-16-2007, 02:42 PM   #11
Detroit Bob
Liked 8 Times in 3 Posts
Question Re: Vinyl Graphic Removal
Won't Easy off penetrate the paint?
Detroit Bob is offline   Reply With Quote
Old 12-16-2007, 04:02 PM   #12
Sean Cour
Guest
Posts: n/a
Default Re: Vinyl Graphic Removal
Astro or Chicago Pneumatic makes a die grinder with eraser wheel attachment. Just like the crud thug from Snap-On, just alot cheaper. Can get from any auto paint supplier.
Old 12-16-2007, 05:14 PM   #13
Smink
Thumbs up Re: Vinyl Graphic Removal
I know it sounds scary..... I figured this trick would raise the naysayers!
Works fantastic. Old trick from way back. Use caution and try a spot of paint on rear quarter lip first.
Smink is offline   Reply With Quote
Old 12-16-2007, 05:34 PM   #14
Sean Kennedy
Sean Kennedy's Avatar
Send a message via AIM to Sean Kennedy
A good friend of mine is a vinyl lettering guy. He is the master of taking off stickers and not taking off paint.
His weapon of choice is a plastic razorblade, i believe you can buy that at auto body supply shops. It's a really thin plastic scrapper basically.
Use your heat gun, or hair dryer and get the sticker really warm, so the glue is loosened up and use the plaist blade to scrape it off.
Sean Kennedy is offline   Reply With Quote
Old 12-19-2007, 06:27 PM   #15
bob gonier
3-M or Astro make the rubber wheels. Kinda like a eraser on a die grinder. Works great on all paint except old Lacquer. Its a little scary at first but it doesn't harm the paint at all. Quick and painless.
But try the heat gun first, its cheaper.
bob
bob gonier is offline   Reply With Quote
Old 12-19-2007, 08:04 PM   #16
Sean Ward
Sean Ward's Avatar
Send a message via AIM to Sean Ward
3m makes a spary for sticker removel works great we use alot of it at the body shop
Sean Ward NHRA s/ss/comp#2882
SW4 MOTORSPORTS
Sean Ward is offline   Reply With Quote
