Old 01-01-2015, 03:21 PM   #1
ken robinson
Liked 215 Times in 86 Posts
Default Rear disc brakes for 5/8 studs
Looking at the strange web sight it doesn't state wheel stud hole dia. 1/2" or 5/8" of there disc hat for gm 12 bolt . Aerospace sales both 1/2 or 5/8 . Wilwood looks like only in 1/2 holes ? M/W is a yes . Anybody got any info ?
Old 01-01-2015, 05:48 PM   #2
Patric Fox
Patric Fox's Avatar
Liked 11 Times in 8 Posts
Default Re: Rear disc brakes for 5/8 studs
I had to drill out my Wilwood hats for the 5/8 studs for a Dana 60. I used a Unibit step drill bit.
Patric Fox is offline   Reply With Quote
Old 01-01-2015, 06:15 PM   #3
Dragsinger
Liked 99 Times in 60 Posts
Ken, all strange rotors are for the 5/8" studs. Strange has a sleeve to adapt to 1/2" if needed.
On the Strange web site note all the brake photos show with studs and nuts. If you scan the site for stud options you will set the 1/2" stud kits with "sleeves"
I have a Strange brake kit for the Super 10 build with 5/8" studs. I installed a symmetrical end on the 12 bolt housing.
Larry Woodfin 471W
Old 01-01-2015, 06:39 PM   #4
FED 387
Liked 333 Times in 180 Posts
put the 5/8 in you will never break a stud in a Stocker or LOW HP SS-- got access to a machine shop enlarge the hats to 5/8 inch-- problem solved
Old 01-01-2015, 07:56 PM   #5
GTX JOHN
Liked 2,485 Times in 697 Posts
X2.........I have broken 1/2 on HEAVY Stocker and
disaster results ( Especially to the Tree )
John Irving
741 Stock
741 Super Stock
Old 01-01-2015, 08:05 PM   #6
MAURICE BLENDHEIM
Liked 284 Times in 87 Posts
Originally Posted by patric fox View Post
i had to drill out my wilwood hats for the 5/8 studs for a dana 60. I used a unibit step drill bit.
x2
MAURICE BLENDHEIM is offline   Reply With Quote
Old 01-02-2015, 03:07 AM   #7
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
All the Strange rotors look like they have 10 holes of two sizes. We are talking rotors - disk hats - right? Call them.
Dale
Old 01-02-2015, 04:15 PM   #8
Dragsinger
The above post by Dale is correct. I doubled checked this morning, the rotors I have for the Super 10 have both bolt patterns.
I always find it surprising when you can look at an item yet never catch all the details. When you are looking for one specific fitment [it fit on my 5/8" studs] there was no reason to notice the second set of holes.
Larry Woodfin 471W
Old 01-02-2015, 11:07 PM   #9
Dragsinger
photo of Strange brake rotor with dual bolt pattern
Larry Woodfin 471W
Old 01-04-2015, 11:41 AM   #10
ken robinson
Thanks guys. There picture looked like the dual rotor hat bolt pattern had 1/2 and 5/8 slotted holes machined on them for use with both sized studs and for height reductions .
