Old 04-18-2014, 11:51 AM   #11
65wagon
Default Re: 65 Plymouth wagon
Originally Posted by James L Miller View Post
A friend of mine used to run a 1965 Plymouth Valiant with the 273. I remember him telling me the 1965 273 had a bigger carb. From the specs from NHRA, it looks like the Stromberg has a slightly larger venturi than the Carter BBD.
180 273 DP 8.8 1-2 B&B BBD-3843S/SM 3844S/AUTO 2463252 1.5 M 57.3 B,5
Carter Carb sizes – 1437/1063
Strom Carb sizes – 1437/1125
It also looks like the 318s got a bigger carb. I never knew they were different.
Awesome thank everybody for the info i am really excited about building this car i have a lot of the parts already just need to figure out what manual trans i can run for sure then i can get started building
65wagon is offline   Reply With Quote
Old 04-18-2014, 12:15 PM   #12
Rory McNeil
Liked 1,104 Times in 302 Posts
Originally Posted by njk53 View Post
If my memory serves me correct the 4bbl Hi-Po motor only came in the Dart and Barracuda and I think it was a 10.25:1 motor w/solid cam.
The 273 CI wagon only came with a 2bbl Carter Ball&Ball carburetor. Not sure if a 4 speed was available.
I am pretty sure you are going to have to run 8.5:1 CR pistons in your combo. However, a 65 Plymouth Wagon would be a cool piece.
Did the wagon come with a 361 or a 383 in 65? I would check out the big block combo because I think they were available with a 4bbl.
You could also get the 235HP 4 barrel 273 in a 65 Plymouth Valiant. I owned a 65 Valiant Signet 2 door hardtop with a 273/235HP 4 speed while I was in Grade 12 in high school. The weak links were the small diameter clutch, and small rearend, which I understand the 66 version had a 8 3/4 diff, but I think all the 273s used a small clutch. Of course that could all be upgraded. Angela Bushmaker races a 65 Valiant 235HP in K/SA here in Div.6, and it runs really well.
NHRA 6390 STK
M/S 85 Mustang
Old 04-18-2014, 12:23 PM   #13
65wagon
anyone know this car or how to get a hold of paul wong this car is close to what i would need to run thanks
Old 04-18-2014, 02:22 PM   #14
Liked 5,121 Times in 1,952 Posts
Do a search of the Classifieds and I'm sure you'll find his number.
Old 04-19-2014, 03:23 AM   #15
GTX JOHN
Liked 2,485 Times in 697 Posts
Leave Paul a message.....He is on this site a bit.
He is one of the most savvy stock racer I know and
has been a help to use many times.
My partner was AHRA Stock world champion with a 361
65 Wagon in 1972. 383 is a excellent combo also.
John Irving
741 Stock
741 Super Stock
Old 04-19-2014, 07:03 AM   #16
Dave Ley
Liked 241 Times in 44 Posts
Send a message via AIM to Dave Ley
Dick Moreland and Clayton Wright are the masters of the 273. Their 65 Wagon has set the record numerous times.
Dave Ley
Dave Ley is offline   Reply With Quote
Old 04-19-2014, 07:37 AM   #17
jmcarter
jmcarter's Avatar
Liked 3,179 Times in 972 Posts
That would be the "Class of 65" wagon which has been owned by David (Rev) and Donna Koopman for many years and restored to it's former glory thru their efforts and the tutelage of Dick and others. They are very busy with work and Rev's ministry but I keep poking them to bring the car back out, it's a beauty. It's graced the pages of many Mopar magazines, I'll have to look for a good picture to post when I get some more time.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 04-21-2014, 08:23 AM   #18
njk53
Rory you are right the small rear end and clutch was a weak link in the Valiant, Dart, and Barracuda combination with the Hi-Po option. It had that 4 inch bolt pattern wheel and at one time you couldn't find nice wheels for it. Later on Cragar came out with a wheeI. I am pretty sure though an 8 3/4 rear end out of a 62 dart fit under the Barracuda with little issue. Brings back a lot of memories mine was a fun car to drive. I would love to find an unaltered Formula S 4 speed car, but they are scarce.
Nelson Kowal
Stock 345
Old 04-21-2014, 09:19 AM   #19
65wagon
Yes please post pics when you can and thanks to everyone for all the info thus far this is a good group of racers on here!
Old 04-21-2014, 12:30 PM   #20
Dave Ley
Not the car I'm talking about although they were involved with that one. I'm talking about Clayton's "Slo-Motion" 65 Plymouth wagon that he still runs.
Dave Ley
