#21 |
Jimmy said the 9" Ford rear does it on the bench. My MPH going up immediately after adding lube (and that/this gear set not wearing) made me think he was correct. If Jimmy told me a pizz-ant could pull a freight train I would start trying to figure out how to hook that little sucker up. :-)
Ed Wright 4156 SS/JA |
#22 | ||
Liked 759 Times in 379 Posts
![]() Last edited by 1320racer; 01-13-2014 at 02:31 PM. |
#23 | |
Liked 1,826 Times in 414 Posts
Jimmy told me this several times, and I'm pretty sure he is correct. I wish I had tried it before we had that 5.00 gear in the 12 bolt go away. Jimmy said it does affect the 12 bolt as well. He also said to use API GL-6 lube. I tend to listen to Jimmy, I've known him since about 1980 or so, and every time I've ignored his advice, it has cost me, one way or another.
Alan Roehrich 212A G/S |
#24 |
Thanks Alan.
#25 |
Liked 2 Times in 2 Posts
Question. If you put seals or baffles in the tubes to keep the lube at the gear do you need to worry about axle bearings?
Kris Rachford 69 Cobra 428CJ 4 Speed C/S 3032 |
#26 |
If your axle bearings are sealed, I wouldn't know why.
#27 |
#28 |
Liked 6 Times in 5 Posts
Quite a few years ago, I read an article in a MuscleCar magazine in which they did a back to back comparison of regular and synthetic lubes in a '69 Hemi Charger with an A-833 4-speed and a Dana 60. IIRC the total difference between dinosaur oils and synthetics in engine/trans and axle was 3 tenths. Car went from 13.00 to 12.70 doing nothing but changing to synthetic lubes.
#29 |
My p.o.s. didn't show anything when I switched.
#30 |
Liked 6 Times in 2 Posts
Alan I had this conversation with mr. B about the gl6 lube but I have not been able to locate any , is it available in the Nashville area? Thanks .
