Old 10-05-2013, 03:57 PM   #1
396chevy
Default lite weight batterys
Anybody had any experience with the lite lithium batterys pros or cons Before I spend the big money for a battery thought I'd better ask Thanks Bill
396chevy is offline   Reply With Quote
Old 10-06-2013, 12:40 AM   #2
Jeff Lee
Jeff Lee's Avatar
Default Re: lite weight batterys
Don't forget the liteweight battery gets it's own battery charger$
Jeff Lee 7494 D/S '70 AMX
Old 10-06-2013, 09:28 AM   #3
396chevy
Ya, I guess that's the other reason I'm being a little cautious. Want to buy the right one the first time. They sure look good on paper and could really use the weight reduction......The weight difference is enough to make my car fit pretty good in next higher class.
Old 10-06-2013, 09:40 AM   #4
Myron Piatek
Liked 138 Times in 51 Posts
Exclamation Re: lite weight batterys
But you can also offset the weight of any front/OEM located battery with a second one of the same weight in the trunk where it will do the most good for traction! It just won't help any plans to move up a class.
Old 10-08-2013, 01:51 AM   #5
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Thumbs up Re: lite weight batterys
Dad ran a Dana Batt for years in his H/PS mustang. it was 13lbs never had any trouble. He even ran it on the street (local track was just 5 miles way)
Old 10-08-2013, 05:34 AM   #6
442OLDS
442OLDS's Avatar
Liked 282 Times in 103 Posts
Same here.I think it is called a Dynabatt. It doesn't need a special charger.
Old 10-08-2013, 02:15 PM   #7
Bill Edgeworth
This is what I used to use;
http://www.summitracing.com/parts/brl-b2015/overview/
It worked OK when running class but was borderline during regular racing constantly starting and stopping in the staging lanes. Does not have much reserve capacity.
Bill Edgeworth 6471 STK
Bill Edgeworth is offline   Reply With Quote
Old 10-08-2013, 07:37 PM   #8
396chevy
Need something with 600 or more cca and some reserve. When you get into the later rounds things start getting hairy. The expensive battery specs seems to have some staying power but really would like to get some input from someone that is using one.
