Old 07-30-2007, 05:26 PM   #1
Ben Kallies
Default Q-jet starting issue
I have a Q-jet on my '71 Corvette Stocker (454/365). Whenever it sits for an extended period of time, the carb will not squirt any fuel. It doesn't matter whether or not the fuel pump is running. So I remove and disassemble the carb, find nothing, reassemble and reinstall the carb and it works fine. This has happened the last 3 times I've let it sit for an extended period. Any ideas? Remedies? Common problem?
Ben Kallies C/S 3869
Ben Kallies is offline   Reply With Quote
Old 07-30-2007, 08:27 PM   #2
SSDiv6
Liked 1,538 Times in 575 Posts
Default Re: Q-jet starting issue
What type of pump material are you using? Viton (rubber) or leather? The leather pump material tends to dry and shrink and not pump.
Old 07-30-2007, 09:42 PM   #3
Ben Kallies
I'm fairly certain that it is rubber. It is whatever Edelbrock sells in their new rebuild kits. Thanks for your reply. - Ben
Old 07-30-2007, 10:10 PM   #4
Liked 1,758 Times in 398 Posts
Is there actually fuel in the carb? Have you tried pushing the float down?
Old 08-01-2007, 04:44 PM   #5
NovaMan
NovaMan's Avatar
It only happens when the car sits for long periods of time... could it be that the gas is just evaporating?
Edit: duh, if the fuel pump is running, that can't be the problem. Note to self: read others' posts thoroughly before replying.
~Pete
1970 Nova
NovaMan is offline   Reply With Quote
