Old 03-26-2011, 10:20 AM   #11
John Lang
Liked 6 Times in 2 Posts
Thumbs up Re: Quick Fuel 780 SSR carb
Adger, Your right on the secondary metering blocks ! 3310-1-&-2 !..........John
John Lang 365 STK, SS
John Lang is offline   Reply With Quote
Old 03-26-2011, 10:32 AM   #12
Ron Miller
Liked 13 Times in 7 Posts
Default Re: Quick Fuel 780 SSR carb
I never knew a 3310-2 was a 780 c.f.m with a secondary rear metering block. I thought any thing after 3310-1 was a 750 c.f.m with a plate. I will keep a eye on the -2 next time at a swap meet.
Ron Miller is offline   Reply With Quote
Old 03-26-2011, 10:33 AM   #13
Dwight Southerland
Dwight Southerland's Avatar
Liked 780 Times in 194 Posts
Adger - You are basically right. The change to the plate and straight boosters was part of the production definition of the -3 and later carbs. I have seen a -2 carb with straight boosters and a block though.
Then there is the original "3878261-EH LIST-3310" carb that was the start of it all . . . .
Old 03-26-2011, 11:57 AM   #14
Bill Harris
Liked 26 Times in 13 Posts
I thought that carb was legal only in SS. Is it a legal replacement for a 780 in stock?
Bill Harris
ex 2172 STK
ex 2272 S/S
Bill Harris is offline   Reply With Quote
Old 03-26-2011, 02:01 PM   #15
340Cuda
Liked 801 Times in 338 Posts
Originally Posted by Alan Roehrich View Post
We have one. It runs very good, right out of the box. I don't know if it is IHRA approved, you need to call IHRA or Phil Vickus at QuickFuel.
Maybe two years ago I asked IHRA for an approved carb list and they said the just used the NHRA list.
Bill
Old 03-26-2011, 04:03 PM   #16
Adger Smith
Liked 880 Times in 311 Posts
Thanks guys, you saved me some time going back over to the shop. I've used it wisely... Working on my race car. I've spent all morning going over my car. I'm trying to get all those little things that never get fixed or looked at taken care of. Someone on here talked about a T-brake tripping at the wrong time. I got to looking at my switch and figured out I was having a similar problem. my T-brake activated going up on the front end lift and going across the parking lot to load up and leave the alignment shop. You know, just a momentary thump/stumble type of apply. Well, best I can tell the little micro switch was set up in the button with partial travel already used up.
I could move the plunger less than .010 and the V/O meter would indicate a circuit. I think the odd /harsh vibrations of my little "V6" was shaking the switch enough to make a intermittent circuit. I took it all apart, moved the slope on the rod .040 and took the diameter of the rod where the switch roller rubs down to .340 depth. the switch lever starts to make contact @ .319. so I now have approx .045 travel in the plunger before the switch completes the circuit. (running SS I don't need the instant apply like a super class car) I also have the switch roller in a position where it is not touching anything when the switch is at rest. My thought there is no harmonics going through the switch lever. Well, I'll try to check it out next weekend. I think I'm going to find that thread and add my findings.
Adger Smith (Former SS)
Old 03-27-2011, 10:55 AM   #17
Kirk Morgan
Liked 80 Times in 44 Posts
Were you running the carb with or without a power valve.
Kirk Morgan is offline   Reply With Quote
Old 03-27-2011, 01:32 PM   #18
Adger Smith
Kirk,
The new David Cook (DC Carbs) 3310-1 carb I'm trying out has a PV in the front and blocked in the rear. It is not the .025 over bore version and had a nice fuel curve. Of course the jetting is not square F to B , but the fuel flow- A/F ratios look good. Up to now I've always run a std bore # 4779 750 by Da Vinvci. I'm not a big fan of PV's but this is the way he sent it and I'm going to try it that way. It does stay clean when idling and at low RPM.
