Old 09-01-2010, 07:45 AM   #11
SCOTT SST2871
Default Re: sst tech questions car under 135mph
check out all the sst cars running under 135, many do not have diapers...for the time being 135 is the break point for license, chassis cert, diapers, gloves, etc etc....135 is where you have to have a legal sg car (plus the weight of course) to run sst.
i was refering to the 3 original questions
flywheel shield/yes
window net if you have cage/yes
fuel shutoff with belt drive pump/yes
scott fifield
SCOTT SST2871 is offline   Reply With Quote
Old 09-03-2010, 02:29 PM   #12
Rollins_2241
I think I disagree on 2 of 3:
Flywheel shield is required at 9.99, not 10.99. Trans shield/blanket is required at 10.99 and for S/ST. So a flywheel shield is only required if you go 135.
Only if the car is "required by the rules" to have a cage is a window net required. If it goes under 135 and has a stock firewall and floor pan, you can have a cage without a net. If not, then yes a cage (and therefore net) is required at 10.99 and for S/ST.
It's a good idea to have the more equipment, the better. And on your first trip thru NHRA tech, no guarantee you won't get an inspector who doesn't know the nuances and says "I am the rulebook!" and gives you trouble. You don't want to have that argument, even if you win on Monday, you lose on that weekend.
Rollins_2241 is offline   Reply With Quote
