Liked 20 Times in 12 Posts
I am looking for a p# for the adjustable brake pressure switch that many are using in stock for there two step. I was told that Grainger sell a switch, that people are using, but I need a part #.
Thanks. Robert |
Liked 66 Times in 29 Posts
go to whitmancontrols.com they have what you need.
Ron Mattson 5015 STK |
Liked 165 Times in 51 Posts
Robert
Is that legal?? |
Liked 4 Times in 1 Post
It is absolutely, positively, 100% legal. I showed the whole setup to Div. 1 tech man Ryck Campbell last year, or maybe the year before.
There seems to be a persistent belief that adjusting the pressure can act as a delay. Low pressure can indeed delay the rev-limiting function shut off, but the wheels will start turning as soon as the brake pressure gets below a certain point, regardless of whether the switch is still closed. The point of doing this is to get the 2 step switch open quickly and consistently, which requires getting the switch off before the wheels turn. Robert- I'll get the part number when I get back to the garage this weekend.
Tony Curcio 1860 STK |
Here is a part number I got from from Alf Wiebe for a pressure switch he uses. It is a switch from GEMS Sensors. 209506. Here is a link to the switch on their web site:
http://www.gemssensors.com/CartAdd.a...tNumber=209506 |
Thanks for the p#'s. Chad that is what I am looking for. Tony, I would appreciate the p# of the switch you use. I also have some questions about your set up. Thanks to all.
Mexjoe, yes it is legal. Robert |
#7 | |
I moved from bracket racing years ago, just to get away from electronics and delay devices? |
Liked 1,784 Times in 407 Posts
A pressure switch used to activate and deactivate a two step is not a delay device.
If I were going to use a pressure switch, I'd also use a brake pressure gauge when staging.
Alan Roehrich 212A G/S |
#9 | |
