I know this is an ongoing subject, but how about some input on most watched and used data.
Currently using a Kestrel 4250. How can water grains info be correctly used? Is there a good source to find a compilation of all the terms and how they affect the car's performance? I really think this forum will supply the answers. Thanks to all. Larry Geddes |
Liked 1,822 Times in 413 Posts
Grains of water is most often used as a reference to relative humidity, it simply tells you how much of the available air is actually water. You cannot burn water, effectively anyway.
You really have to make some runs and see what affects your particular combination, and to what degree. Not all engines react the same, especially if you consider the state of tune. The best way to use a weather station is to create and use an Excel spread sheet, so that you can accurately record each weather condition, and how it affected your car, and then go back and determine how much each condition moves your ET and MPH for a given amount of change.
Alan Roehrich 212A G/S |
Liked 880 Times in 311 Posts
When dealing with weather Data and tuneup IMHO there is no one part of weather data that is More important than any other. I say that because there are are so many combinations and cross combinations of weather/air mass that can give the same or very similar performance parameters. Use all the data....
Adger Smith (Former SS) |
#4 | |
You could quite easily and literally write a book on this subject. It simply cannot be adequately covered here in the constraints of a BBS post.
Liked 129 Times in 59 Posts
I just started to use the Kestrel 4250, so I'm not quite up to speed yet, but the idea is to collect as much data as possible ( temperature, humidity, altitude density and so forth) to establish a pattern of how your car reacts to changes in the weather and it's effect on performance. Once that information is obtained, you can track changes. Kestrel also offers a data logger to connect the 4250 to a computer to build the Excel spreadsheet that Alan mentioned, too!
Now to find a good ET prediction software package!! Lew
Lew Silverman #2070 "The Wagon Master" N/SA |
#6 | |
Thanks, Alan!!
Lew
Thanks.....guys
There are a few books and articles you can read to learn more. I think the Dragster had a couple of David Reher articles, somewhere there is some stuff written by Jere Stahl. You've got a great weather station, I'll be getting one of them soon.
#10 | |
Liked 1,583 Times in 582 Posts
