Old 01-02-2010, 11:20 PM   #11
JRyan
Liked 112 Times in 31 Posts
Default Re: ahfs question
Mark,
I don't think it's an either/or situation applicable to all classes. NHRA was just stating that adjusting HP (for Stockers/Superstockers) --- OR --- Index (for Comp style cars and Hemis) would be at their descretion. In other words, the 1.25 under barrier may not be anchored in concrete.
Jerry
Old 01-03-2010, 12:20 AM   #12
Liked 5,121 Times in 1,952 Posts
Jerry, I can't think of a past example where they have done anything other that the 1.40 hits or the AH index reduction because of the exclusivity of the combo.
Can you?
Old 01-03-2010, 01:37 AM   #13
JRyan
Mark,
No, I can't. But since the inception of AHFS, NHRA has never intimated that changes could be made "at the discretion of the NHRA Tech Department". Now they have. Which might mean that a 1.25 under run at Boise in the Spring in mineshaft air may not get HP or Index.
Jerry
Old 01-03-2010, 10:32 AM   #14
art leong
Can you?
Yes I can.
They gave me 13 horsepower at once The car was rated at 152 they raised it to 165 (in one hit). And at the time, I never went fast at a national event.
Do the math how does 3.25% of 152 equal 13 . By my non fuzzy math it comes out to 8%.
Thats were there discretion comes in. You have to play by the rules, THEY DON"T
Art Leong 2095 SS
Old 01-03-2010, 02:38 PM   #15
JRyan
Art, they multiplied the 3.25% times 2.5 atmospheres for the amount of boost you were running at the time, and it comes about to around 8%. As good a guess as any, huh?
Jerry
Last edited by JRyan; 01-03-2010 at 03:03 PM. Reason: Add the word atmospheres which I forgot
Old 01-03-2010, 06:10 PM   #16
art leong
Jerry
You guessed wrong.
You guys with this boost stuff should really read a bit before you post about the evils of boost. How much boost do any of you think I was running? Do you honestly think you can put unlimited boost into an engine? Remember this was a stocker You can't run huge water to air intercoolers. I couldn't run any intercooler at all. The only adjustment I had was fuel pressure. 95% of the stockers out there flow a lot more air then a stock head would flow. But if you add a few pounds of boost people think you have this huge advantage, and anybody could go just as fast.
The car I run now has no intercooler either. I have to ice the intake manifold to go fast
Just like everybody else.
Art Leong 2095 SS
Old 01-03-2010, 11:07 PM   #17
JRyan
Art,
It was supposed to be a light-hearted way of explaining how NHRA got there. It just so happens that 3.25% times 2.5 comes out to 8.125%. Pretty close to the 8% you mentioned. Sorry!
Jerry
Old 01-04-2010, 09:35 AM   #18
art leong
Art,
Jerry
I'm sorry Jerry. Didn't mean to jump on you.
It's just that the boost is a touchy subject with me. And whether I got hurt by the horsepower or not, they broke their own rules by doing it.
Art Leong 2095 SS
Old 01-08-2010, 06:08 PM   #19
Chris "drooze" Wertman
Chris "drooze" Wertman's Avatar
Has anyone done a spreadsheet of this for the various tracks that could take the records list and autocalc it across ?
If its sounds like something that someone else would like to do/see but dosent know how, I know how to do the excel part I just need someone to check/verify a couple of the calcs as well as be 100% sure Im putting the right info into the sheet.
PM me if youd like it, personally Id like a list of all the records and what has to be run where to beat them on alt factors.....I like it all laid out in front of me....
Cheers
Ty,
Do you know that if you run 1.25 under the altitude factored index for the record, that you don't get the record at 1.25 under? It's LESS than that, and it varies dependant on which altitude track you set it at and the correction factors applied when it's factored back to sea level. So then it really isn't a 1.25 under run, and shouldn't be the cause of a HP factor. But we have no clarification on that either!!
The fact that NHRA personel previously had to do a bunch of paperwork to figure this out at altitude tracks is the reason they just let altitude factored runs go until now.
Jerry
Chris "drooze" Wertman is offline   Reply With Quote
Old 02-11-2010, 03:24 AM   #20
Tom Moock
Liked 10 Times in 6 Posts
Anybody known the answer? Altitude tracks at national and division events, 1.25 under altitude index or 1.25 under sea level index ? AHFS Can somebody ask at the Winternational`s? Tried to call Bruce no answer. Tom
Tom Moock 5704 STK
Tom Moock is offline   Reply With Quote
