Old 07-28-2009, 09:37 AM   #1
HIGHOCTAIN2000
Default Valve spring life
I hear talk of superstock racers that have to change valve springs after 10 runs, is this for real? I know they run nearly an inch of lift, and almost 9000 rpms, but nascar runs 9000 for 500 miles. THOUGHTS.
HIGHOCTAIN2000 is offline   Reply With Quote
Old 07-28-2009, 11:15 AM   #2
BlueOval Ralph
Banned
Default Re: Valve spring life
NASCAR Cams are smooth cams and no where the jerk a good Drag Race cam has.
BlueOval Ralph is offline   Reply With Quote
Old 07-28-2009, 03:19 PM   #3
rx dealer
Liked 53 Times in 13 Posts
It depend on what class you're running. Since I use the "441" casting SBC head i'm limited on how big my valve spring pocket can be cut for the 1.64 spring without hitting a water jacket, so I use the 1.55 spring and yes you get only 10-15 runs out of a set, and it could go either way depend on how high you rev your motor. Luke
rx dealer is offline   Reply With Quote
Old 07-28-2009, 07:23 PM   #4
Danny Ashley
Liked 110 Times in 29 Posts
I was told the hot set-up in valve springs for Super Stock are PAC . Used on a lot of Pro Stockers and Comp engines. Suppose to have long life. Check them out at racingsprings.com.
Danny Ashley is offline   Reply With Quote
Old 07-29-2009, 04:12 PM   #5
Ed Wright
Ed Wright's Avatar
I really like the 1.5" dia PACs. Got mine from Patterson Racing Engines.
Ed Wright 4156 SS/JA
Old 07-29-2009, 05:00 PM   #6
Joe Schweigert
Joe Schweigert's Avatar
Liked 19 Times in 8 Posts
It's like anything "You get what you pay for" Comp #26082 should last over a season
Joe Schweigert 751 SS
Joe Schweigert is offline   Reply With Quote
Old 07-29-2009, 07:01 PM   #7
Tom Meyer
Liked 354 Times in 120 Posts
I use 947 comp springs 1.85 installed ht 400 lbs on the seat will set in about 380 to 360 will last me 2 years or about 300 plus runs on my 283 520 head. I shift at 9000 same in the lights. Camshaft and rockers ratio have a lot to do with it along with harmonics. Tom
Tom Meyer 5240 SS Stock ???
Old 07-29-2009, 07:04 PM   #8
Jesse Knapp
I agree. I used Comps #947 springs and they lasted the season.
Jesse Knapp 4899 STK, SS
Jesse Knapp is offline   Reply With Quote
