Old 04-29-2009, 11:03 PM   #1
House of Darts
Liked 20 Times in 15 Posts
Default Aluminum 8 3/4 Housing
Any thoughts on using Mopars' aluminum housing w/billet caps in a 440 Dart Stocker? Will the 742 hold the torque?
House of Darts is offline   Reply With Quote
Old 04-30-2009, 10:51 AM   #2
Jeremy
Default Re: Aluminum 8 3/4 Housing
I don't think NHRA would like that in Stock.
Jeremy is offline   Reply With Quote
Old 04-30-2009, 11:14 AM   #3
Dusty Lowell
Dusty Lowell's Avatar
Send a message via AIM to Dusty Lowell
Cool Re: Aluminum 8 3/4 Housing
Dusty Lowell
#1773 STK F/SA
Dusty Lowell is offline   Reply With Quote
Old 04-30-2009, 12:32 PM   #4
Chuck Beach
Chuck Beach's Avatar
Liked 58 Times in 13 Posts
Send a message via AIM to Chuck Beach
Dusty,
You can use one in stock and MOPAR (if they are still in business) pays contingency. The problem is when you break a rear end it will usually break the aluminum housing. Been there done that. I asked several manufacturers if they can fix it and they said no ... they are about 11 lbs. lighter than the cast one and are not suppose to flex as much, but they are expensive and won't take the impact of a rear end breakage ...
Chuck Beach
3340 STK
Chuck Beach is offline   Reply With Quote
Old 04-30-2009, 01:47 PM   #5
Jeremy
Chuck, I asked NHRA about this a couple of year ago and they said no. I think I still have the letter some place. Maybe this has changed, but are you sure as I would like to use one.
Thanks Jerry
Old 04-30-2009, 01:50 PM   #6
Chuck Beach
I ran one for over 3 years before I broke it ...
Chuck Beach
3340 STK
Old 04-30-2009, 05:05 PM   #7
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: Aluminum 8 3/4 Housing
If the aluminum center section is listed as a Stock class contingency item, it should indicate that it is legal for use in Stock. It is legal in IHRA and I've been using it for almost 2 seasons. I thought I would be hearing some noise and possibly replacing the ring & pinion by now, but it seems to be holding up rather well. I've only had high 1.40 60' times, usually 1.50-1.51, but I have to weigh 3,530+ lbs.
On a similar note, the Moser 8 3/4 housing has been approved by NHRA for Stock!
http://www.dragracingonline.com/agen...0-xi_4-56.html
LOCOMOTION Racing
Old 04-30-2009, 10:32 PM   #8
Paul Precht
Paul Precht's Avatar
Liked 327 Times in 121 Posts
Are we talking about carriers or housings
Old 04-30-2009, 10:51 PM   #9
Jeff Lee
Jeff Lee's Avatar
Regarding NHRA, maybe Evan Smith could chime in on the illegality of aluminum center sections.
Jeff Lee 7494 D/S '70 AMX
Old 05-01-2009, 12:46 PM   #10
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Jeff,
That's a Ford and he is a technical expert who is a published author in National Dragster.
Now my plan is to put a Ford 9" housing with a Strange Aluminum 12 bolt center section in our stocker and see if we can sell that to NHRA.
Bob
Bob Mulry 7516 STK
A & M Motorsports
