Old 06-26-2024, 07:14 PM   #1
dean ribeiro
Liked 235 Times in 75 Posts
Default Brake Pressure Switch for launch control ???
I have a new stocker that has a brake pressure switch for launch control and I am trying to understand how it works and how to set it properly? I am just an old 2 step switch kind of guy (and am easily confused).
Any help is greatly appreciated!
Text or call six03-78five-seven866
email: deanribeiro@comcast.net
dean ribeiro is offline   Reply With Quote
Old 06-26-2024, 07:52 PM   #2
Jeff Stout
Liked 704 Times in 281 Posts
Default Re: Brake Pressure Switch for launch control ???
Look up Folk race cars. They have one worked really well. They are in Illinois last i heard.
Old 06-26-2024, 08:44 PM   #3
GTS340
Liked 1,342 Times in 409 Posts
here is one.Does it look close?
Paul H
Name:	Brake pressure switch.PNG
Old 06-27-2024, 09:38 PM   #4
SDT1DYI
Liked 455 Times in 147 Posts
Folk Race cars closed. The switch you want has an adjustable pressure Range 100 to 1000 PSI. 3 wires. Black wire is not used.
Recommend wiring power to it thru a 3rd gear micro switch.
Power is removed to the BPS when in 3rd gear ( if a 3sp Auto)
This will allow you to apply brakes at 1,000 and the 2 step will not be activated.
Set up a LED light in the circuit so you know when the 2 step is powered up with right brake PSI
Believe they are 200.00 or so.
Steve Teeter Stk/SS 620
SDT1DYI is offline   Reply With Quote
Old 07-16-2024, 08:12 AM   #5
Bobby Fazio
Bobby Fazio's Avatar
Has anyone done this with Precision Shifter forward pattern? Can someone send me a pic or point me to a good reliable microswitch and mount? Thanks!
'65 Mustang SS/L & L/SA
Old 07-18-2024, 04:35 PM   #6
Barry Polley
Guest
Posts: n/a
I did that to my PP shifter Bobby, only activates in first gear. I mounted to the right side. I?ll take pics when I get home. Same brake switch too..
Old 07-19-2024, 08:02 AM   #7
Bobby Fazio
Thanks Barry! You can PM me or email me bobby.fazio@gmail.com.
Old 07-23-2024, 12:20 AM   #8
Barry Polley
Guest
Posts: n/a
Pics and video sent Bobby..
Old 07-19-2024, 11:36 PM   #9
SDT1DYI
There should be a micro switch that PPP can supply that mounts opposite side of the Netural safety switch. It's triggered by the same rod. No external bracket and switch required then . Very clean and they provide a screw on connector wiring harness same as the Safety switch hasness .
Old 07-20-2024, 04:29 PM   #10
Ben Holt
Liked 112 Times in 40 Posts
Just curious how much brake pressure do you use at the starting line? I have seen a lot of data and have never seen brake pressure over 4-500 psi (on 160 mph plus cars). I would think anymore than that would lock em up bad at the stripe.....
Ben Holt is offline   Reply With Quote
