When we got the car it had some extra camshafts. This is a nhra stocker. We have a lunati p/n 51099. No tech card or anything. Hoping someone has some information on it.
This is what is on the box. Lunati 51099 PRN1-RL-COBRA1110 FORD 351 WINDSOR PAEA |
Liked 50 Times in 28 Posts
I found this on the web, I don’t believe that’s a legal cam:
https://www.motortrend.com/how-to/m5...e-stroker-kit/ |
#3 | |
Liked 183 Times in 82 Posts
Spec's Lift .646 int/exh w/1.6 rockers, 268 int / 280 ext duration @ .050 on a 106 lobe center. Other sites that people asked about this cam were directed to try Bullit cams for help
Brian Stk B200 |
Yeah. I have seen all those on the internet when I did the search. This cam if from the early 2000s. We checked the lift at the cam. Definently not those. If it was I would not have posted here. We called to talk to someone and was told when holley bought lunati they discarded most of that information. We were hoping someone may have ran it back then and still had info.
Liked 735 Times in 386 Posts
My Lunati catalog shows 51099 as custom grind and no other information.
This is what I found on the internet. Solid Roller Cam. Excellent cam for bracket racing applications in the 10 second range with good mid range and upper RPM torque and HP. Needs 4000-4500 RPM stall converter, headers, 11:1+ compression ratio and 4.30+ gearing. Rough idle. ; Advertised Duration (Int/Exh): 296/308 ; Duration @ .050 (Int/Exh): 265/276 ; Gross Valve Lift (Int/Exh): .668/.668 ; LSA/ICL: 106/100 ; Valve Lash (Int/Exh): .028/.028 ; RPM Range: 4000-8000 ; Includes: Cam Only Stan |
Ok so from what I am gathering from all my research and what you all have came up with 51099 just means custom grind cam.
I have found the next number is the custom grind number. And if they got rid of all that information when holley bought I am out of luck. Thanks everyone for the input. |
Liked 776 Times in 199 Posts
Paul, We had a Foxbody GT and ran 11.90's in M/SA in the early 2000's with a Bullet cam. Also, if your car is a GT which I think it is, you can call it an 87 and it's a natural L car. You might have my old car. We ran a 95 Cobra R stocker in the late 90's before we built the Foxbody and it was a 351W and we ran a Lunati cam in that car with 106 lobe separation. We sold both cars to the same guy. He might have accidentally given that cam to the guy who bought your car.
Bret Velde 2003 I/SA Last edited by BRETV; 01-07-2024 at 02:39 PM. Reason: info |
#8 | |
Liked 520 Times in 176 Posts
When in doubt, see if someone in your area has a Cam Doctor or something like that and they can spin it for you and you'll get lift, duration and opening and closing ramp speed numbers. The Cam Dr. cant do lobe centers, but if you think its usable then stick it in a block with a crank and one rod and piston and figure the Lobe Separation numbers with a degree wheel and a dial indicator. Good luck with your new pieces. Respectfully, Henry Kunz 1534 H/SA |
#9 | |
Liked 163 Times in 54 Posts
Lunati is part of the Edelbrock Group. Edelbrock, Comp Cams. TCI, F.A.S.T., Russell and Lunati.
Div 3 Sales, Service and Tech for many manufacturers |
