Liked 4 Times in 1 Post
Hello! I am looking for help on rear suspension setup. This is primarily a bracket car but would like advice from you Stock Eliminator guys as I really want my suspension to just work to get my 60ft as low as possible. Right now the engine is just bolt-ons plus a 503 cam (maybe 375 hp?). Trans is a manual TH350 with app. 3500 stall converter. Rear is 4.56 and all suspension is stock except a Midwest Chassis adjustable torque arm. 28" tall tire. Any help would be greatly appreciated! Also, front suspension is all stock and any advice there would be great, too.
I was in Vegas last weekend hoping to visit with some of the Stockers, but didn't see any 3rd/4th gen guys there. Thank you for the help! |
Liked 216 Times in 77 Posts
I run the S&W Racecars stuff in the back of both my stocker and bracket car. (Torque arm, pan hard, lower control arms and anti roll bar) As for the front. Get rid of the sway bar. Put the good bushings from global west in the control arms. And a set of shocks. And you should be pretty good.
#4 | |
Thanks again, Rob. Greatly appreciated! |
Liked 10,838 Times in 2,253 Posts
Work on the front suspension first to get the weight to transfer to the rear. Put the car on four wheel scales race ready with the driver race ready, with helmet on and see what you have and help target where you want to go. Might want to go to 9x30 tire to get a larger contract batch front to rear.
#6 | |
Liked 166 Times in 71 Posts
Adjustable rear lower arms and the rear lower relocation brackets actually aren’t allowed in stock, and you shouldn’t need them.
Chris Chapman 1969 Chevelle NHRA F-G/SA 1090 |
I thought that was the case. Good to know! It's nice to see that I don't need the adjustable stuff. Sometimes (for me) too many options makes it more difficult to get it nailed down! So, just the tubular bolt-in stuff with poly bushings?
Liked 228 Times in 70 Posts
Tubular nonadjustable lower control arms. Frame reinforcement kit from S&W and a good anti roll bar is all you should need. Stock springs work fine if it sits too high you can remove the upper rubber from the spring. All of the stockers you see have weight in the rear. Afco shocks from Fastshocks for the front are most critical. Even stock gas back shocks work fine as long as they are in good shape.
#10 | |
