Hello, i have a 67 camaro stocker, and going to bye a aluminium radiator, so...i think of a direct fit with a fan. Are there any brand who are better then others? And can i use a two row radiator if i have a small block engine?
Torbjorn Laas Sweden |
Liked 10,837 Times in 2,252 Posts
Use the one that is the lightest when full of water.
Liked 162 Times in 45 Posts
I went to the local chain parts store and ordered a replacement radiator for a six cylinder for my year. Single core aluminum with plastic tanks. About a hundred bucks. Perfect fit. Car runs as cool as it did with the factory radiator and I lost five pounds off the front of the car. Ow if I could get the driver to lose a few pounds!
Liked 883 Times in 237 Posts
For a Stocker , Id use a 2 row from Champion Radiators.
They have a direct fit model .
Thank you for your answers, Painter, which year do you have on your car?So you don`t have any heating problems?
My car was an original 1970 6 cylinder automatic. So that’s what I ordered. Perfect fit and I think the car runs cooler!
What brand is it? I didn`t found any plastic radiators on summit.If your car is a 1970 maybe i can find to my 67. Du you have any electric fan on the radiator?
Liked 30 Times in 17 Posts
tolass,
I had a 67 that I bracket raced for years. I am not sure what you guys are allowed to do as far as modifications but somewhere along the line I installed a radiator out of around an 85 Camaro. Aluminum radiator with plastic tanks with the attached shroud / electric fan combination. It was very light and worked fine cooling an approx 550 hp small block. I had to do a slight modification to the core support because it was a little wider than the stock radiator but it was nothing major.
Bill Koustenis |
