Liked 286 Times in 73 Posts
Evan Smith wrote a really nice article in National Dragster about sway bars, but are there other ways to make a car do the same thing. Weight preload, shock settings, shortening the passenger side upper bar on a 4 link, spring rates. Or, are each of these items doing something different than the sway bar accomplishes. One time, my Super Bee was picking up the left rear quarter a considerable amount, but the right rear was doing nothing. I had all of the clamps off the right, but no lift. Finally, I started clamping the left, just to calm it down. It did, but it also started lifting the right. I had no idea that the torque would transfer to the other side of the car. Last question in all of this: Is a sway bar even an allowable addition to a Stock Eliminator car?
Greg |
I have seen them on cars that never came with them.
I even saw at Indy a few year ago an A Body Mopar with the front sway bar installed on the rear axle! I discussed it with the gentleman and he said the rule did not say where sway bar could be placed
Liked 225 Times in 136 Posts
Great point but it also did not say he could move to rear! That’s what the Tech guys answer would be.
Liked 51 Times in 30 Posts
yes I read article also, building 1975 mopar b body M/AS was going to leave factory rear bar and make adjustable links
Brakes & Suspension:3
Suspension, Rear "Sway bar(s) optional" I seem to remember that a couple of years ago the Tech Dept. came out with some kind of a ruling that a "sway bar" or an "anti-roll bar" from the aftermarket couldn't be "welded in" but had to be "bolted in" a Stocker.
#7 | |
Liked 269 Times in 99 Posts
S&W made a roll bar kit for 3rd gen Camaro a lot like what is used in 4 link suspension installed above the axle housing with torque tube mounted to the body with adjustable links which drop down to the axle housing.
