Liked 239 Times in 90 Posts
Hypothetical question. I know with sbc intake castings(iron) the castings vary a good bit. So, 2 intakes, same casting number, obvious diff production dates. One has around .070 avg wider ports at gasket surface on all ports. is this much variance normal?
Liked 880 Times in 311 Posts
Let me make a guess... the wider/bigger one has an earlier date code..
Adger Smith (Former SS) Last edited by Adger Smith; 08-16-2020 at 01:26 AM. Reason: sp |
Core shift due to an acid trip???
OK, here is what my friend JV Brotherton (Owner of Brodix) told me when I was complaining about port size/Vol matching specs.
As the molds are used the ports shrink due to the wear on the mold. I'm not a mold maker so I took him at his word. He said the early part of the production run will be on size and the tail end will be smaller. I was hoping someone that knew the mold process at GM would take the bait and tell us. I hope that helps. BTW I always flow the manifolds to be sure.
Adger Smith (Former SS) |
#6 | |
#7 | |
Liked 976 Times in 311 Posts
Liked 456 Times in 148 Posts
Best to test intake manifolds on a dyno. They can be different. In one case 15 "stock' CI manifolds same casting #, were tested on one engine , same day. HP varied 15 .
Steve Teeter STK/SS 620. |
