Liked 184 Times in 113 Posts
Fuel Tech
If one track does not have VP or Sunoco. Will is mess us Fuel Check if needed to go with the other Fuel? Or Sunoco GTX and Supreme D Last edited by Dan Fahey; 11-10-2019 at 04:16 PM. |
Liked 1,471 Times in 308 Posts
Yes.
Liked 315 Times in 178 Posts
Hey: Name one NHRA track that does fuel check for class cars and does not sell VP, Sunoco or some other brand that is on the accepted list.
Very confused....
FUEL CHECK... What are they checking for? Specific Gravity? Mixing an Unleaded Fuel Sunoco 260GTX and Leaded Supreme. Both listed as legal fuels would cause a car to be DQed? This does not make sense.. Not every track has all the blends. Especially Sunoco 260GTX Dan Last edited by Dan Fahey; 11-10-2019 at 11:10 PM. |
Liked 73 Times in 36 Posts
Fuel check is using a dielectric constant meter that has been zeroed against a standard such as Cyclohexane or Indolene. Typically Cyclohexane. IF it passes, ok....IF not, yer outa there regardless of what fuel you claim.That method of NHRA fuel check has been in place for many decades.
Now I heard that if you used some 1,4 dioxane.......well, that is another story. LOL Regards, HB2 ![]() Dissident |
#6 | |
Liked 225 Times in 88 Posts
#8 | |
Liked 1,443 Times in 302 Posts
James Schaechter 3163 STK |
#9 | |
Just do not see it much at the tracks. Then Forced to run the Leaded. |
Liked 2,007 Times in 602 Posts
I prefer VP fuel and have a distributor close to me. I purchase my fuel there and carry enough with me for the race. Typically I carry about 15 gallons along with me. In the past I have had difficulties with the Sunoco fuel and fuel check so I went back to VP. Very rarely do I have any issues with fuel check using VP C12. If you mix the fuel you will have problems at fuel check. Sometimes if you change fuel and don't get all of it out of the system before the new fuel is put in it can cause it to fail. Best is to pick one type of fuel and have enough on hand so you don't have to go through those gyrations.
Mike Pearson 2485 SS |
