Old 04-16-2017, 05:08 AM   #1
Hudlow66
Hudlow66's Avatar
Default A better "glue" for your rim-to-slick mounting
Has anybody found a better adhesive than the Permatex Hi-Tack, when mounting their slicks without screws? Ive got new rims and was thinking about going screw-less. Mainly because I hate the idea of drilling on my new rims. They're bias Hoosiers 26X8's on a 15X8 rim, if that makes any difference. Usually run (about) 16lbs, for air pressure. Also, currently running tubes and toying with the idea of leaving them out, this go around. Would "that" make a difference in going screw-less or not. Thank you! I'm a bit of a newbi, when it comes to small tire stuff
Phil Hudlow 6678 (S/C, S/G, ET-PRO)
Hudlow66 is offline   Reply With Quote
Old 04-16-2017, 08:02 AM   #2
SSGN
SSGN's Avatar
Liked 203 Times in 52 Posts
Default Re: A better "glue" for your rim-to-slick mounting
I was under the impression that dry was the best. Interested also on any feedback
The more people I meet the more I like my dog
Kevin
Old 04-16-2017, 08:21 AM   #3
SGSST109E
Liked 126 Times in 61 Posts
Have run tubeless for 20 years. Have run screw less for the last 10 years. 14 x 32's bias and radial. Just mount the tire dry. They may move a little on the first hit or two then then usually stay put.
SGSST109E is offline   Reply With Quote
Old 04-16-2017, 08:23 AM   #4
Ed Wright
Ed Wright's Avatar
I just have my MT radials mounted dry. No screws, etc.
Ed Wright 4156 SS/JA
Old 04-16-2017, 11:21 AM   #5
Hudlow66
Hudlow66's Avatar
If wiping 'em clean and dry is all that's needed (not the typical soap, glue, witchcraft, etc.), I'm down for that.
Old 04-16-2017, 11:27 AM   #6
Hacksaw
Liked 314 Times in 177 Posts
I use a glass cleaner, like Windex. There is a small amount of lube to help the bead set and it dries quickly.
Old 04-16-2017, 11:40 AM   #7
Hudlow66
Hudlow66's Avatar
Y'all just mounting them at home?
Old 04-16-2017, 04:23 PM   #8
Eman
Liked 133 Times in 76 Posts
I break and mount my slicks at home. I've had a pair of MT 10.5's where one tire was moving inches every week. broke it down, wiped bead with acetone and sprayed hair spray on the bead then aired it up. Worked great, no more slip, clean and nothing to clean up when I replaced them. That's the only tire I've ever had move and haven't used screws in years and have run Phoenix,Hoosier and MT.
Old 04-16-2017, 06:25 PM   #9
SSGN
SSGN's Avatar
Thumbs up Re: A better "glue" for your rim-to-slick mounting
I remember we use to put that on handle bar grips on our mountain bikes and they never moved. Thanks, for got about that
Kevin
Old 04-18-2017, 09:14 AM   #10
Run to Rund
Liked 56 Times in 29 Posts
I sandblast the bead areas of the rim and use no lube.
