Old 01-01-2017, 12:41 PM   #1
Kdw1403
Liked 68 Times in 22 Posts
Default LT 1 350 valve to piston clearance
What is minumun valve to piston clearance? i have .100 on intake and .60 on exhaust. I am a little nervous about exhaust side. Is it legal to cut the exhaust valve pocket on the piston just a little? nhra stocker
Kdw1403 is offline   Reply With Quote
Old 01-01-2017, 01:14 PM   #2
Bob Gullett
Bob Gullett's Avatar
Liked 510 Times in 117 Posts
Default Re: LT 1 350 valve to piston clearance
Is that checked with checker springs or the regular springs?
68 Chevy11 327 F/S
Bob Gullett is online now   Reply With Quote
Old 01-02-2017, 01:44 AM   #3
Kdw1403
It was with checker spring. I have since used my regular spring and it reads .080 with everything just like i am going to run it in the motor.I am new to stock. I raced super gas for years. Just dont know how far you guys push the envelope in stock eliminator.
Old 01-02-2017, 10:30 AM   #4
Bob Gullett
I figured it would pick up some clearance with regular springs. .080 is quite adequate.
68 Chevy11 327 F/S
Old 01-02-2017, 05:25 PM   #5
RichScaz
RichScaz's Avatar
Check your PM.
RichScaz is offline   Reply With Quote
Old 01-01-2017, 01:42 PM   #6
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
I do not think so.
265 55 Chevys sure wish they can notch their flat pistons to get some valve tolerance.
D
Old 01-01-2017, 02:10 PM   #7
Ed Wright
Ed Wright's Avatar
I do not think so.
D
Having raced 265" '55 & '56 Chevies, we damn sure flycut our flat top pistons for valve-to-Piston clearance. Mine was down 4 times by NHRA, three national records & once was protested, passed every time.
Ed Wright 4156 SS/JA
Old 01-01-2017, 02:29 PM   #8
MR DERBY CITY
Liked 8,218 Times in 1,537 Posts
Ed, we are talking STOCK eliminator.....Alan is correct. I might add just watch yourself in the water....
Old 01-01-2017, 03:44 PM   #9
Ed Wright
Ed Wright's Avatar
I apologize. The Stock rules are different enough from when I ran Stock with that '56, I should have kept quite. About all he can do legaly is move the cam.
I don't get the remark about water?
Old 01-01-2017, 03:55 PM   #10
TOSTO RACING
TOSTO RACING's Avatar
Liked 663 Times in 187 Posts
I think he is referring to don't let it get away from you on a burnout. People tend to over rev a car in the water box.
As for vtp like Alan said above .060 .065 exh would be as tight as I've ever ran and it was okay for me. The intake is more forgiving. if I were you I'd advance the cam and get yourself some more exh clearance and less int in my opinion if you are worried about it .
Good luck with it.
5664 GHI/SA
1985 CAMARO RED H/SA
1985 CAMARO BLUE I/SA
TOSTO RACING is online now   Reply With Quote
