Old 08-02-2016, 06:42 PM   #1
Tim H
Tim H's Avatar
Liked 484 Times in 160 Posts
Default Automatic trans shifting
I am wondering if any of the Stock racers have ever set their transmissions up to shift automatically.Just finished watching the video of Sterling Simmons C/SA (in the magazine portion of this site) and you can clearly hear the rpm change yet the shifter handle doesn't seem to move. Would the computer in the car be controlling the shifts with the shifter left in "D" or ?
Old 08-02-2016, 06:56 PM   #2
Liked 1,909 Times in 427 Posts
Default Re: Automatic trans shifting
In Stock Eliminator, cars originally equipped with automatic transmissions that were shifted electronically by the computer as delivered from the factory can use "E-shift" systems, even on transmissions that were not original to the car, and did not originally have "E-shift". So a late model EFI car can use "E-shift", but an older carburetor equipped car cannot. Some older cars are equipped with "auto 1-2" valve bodies. Those cars leave the starting line with the shifter in 2nd, but the car leaves in 1st, then shifts to 2nd at a pre set RPM. The "auto 1-2" feature is controlled by the governor and the vacuum modulator in most cases.
Old 08-03-2016, 10:36 AM   #3
Mickey Whaley
Lightbulb Re: Automatic trans shifting
I think paul forte at Turbo Action lobbied to make it legal for the older cars but got shot down I think if they can have we should too C/sa
Mickey Whaley is offline   Reply With Quote
Old 08-03-2016, 11:19 AM   #4
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
My Opinion: Stock trans with OEM electric shift is OK unmodified. Otherwise, all transmission shift upgrades should be driver activated. It's called racing, not programming for Gods sake.
Dale
Dale Shearon
68 Mustang 6394
Old 08-03-2016, 12:30 PM   #5
Coleydog
Liked 53 Times in 38 Posts
What about a stock 727 ? No plates or vb just put it in drive and go.
Old 08-03-2016, 07:54 PM   #6
Tim H
Tim H's Avatar
I am not a Mopar racer but I doubt a stock 727 trans will shift automatically at 6500 rpm or so without modifications. Most of the older OE trans shift far too low in the rpm range for use with a stocker camshaft.
Old 08-15-2016, 01:43 PM   #7
Bobby Fazio
Bobby Fazio's Avatar
Liked 4,379 Times in 502 Posts
I think if you are going this route then you'd better be racing with the 4L60E transmission that e-shift was used on! Running a TH200 or 350 with e-shift should be illegal. Those transmissions never came with an electronic shift and this whole E-Shift bull**** in stock eliminator has gotten way out of hand. How is this any different from super stock?
'65 Mustang SS/L & L/SA
Old 08-15-2016, 05:47 PM   #8
James Perrone
Liked 1,853 Times in 433 Posts
Talking Re: Automatic trans shifting
I have a200 metric. Auto 1-2. Shifts of governor. Bolt thru pan to adjust shift point In my super stocker I shift it because it's a power glide. Too easy. Ya I cheat
james perrone 1290 STK
James Perrone is online now   Reply With Quote
