Liked 16 Times in 11 Posts
Hi
I need information. On my B/SA 1995 Camaro with LT1. At 101.5 timing, the valve clearance to piston is .018 int and .053 on exh. It is too tight or is normal. If i back the cam at 106, i have 32 int and 36 exh. All with .039 head gasket. what you do with this? Thank for your help |
Liked 239 Times in 114 Posts
How are you measuring that ? Light checking spring, or clay, do you have a welded lifter ?
This is Roller Hydro. but I checked the lash with light spring and solid roller lifter. but i have same result with light spring and roller hydro.
Liked 209 Times in 46 Posts
what is the total deck, head gasket and piston depth?
Also what is cam ground on? |
Liked 121 Times in 11 Posts
Mark you have a pm.
Joe DeMarzo 1317 STK |
deck is .015 gasket .039 total .054.
but i want know? Have you ever seen this in stock eliminator for a hydraulic roller cam? |
