Old 05-28-2015, 08:39 AM   #1
RobbieRacer
RobbieRacer's Avatar
Liked 118 Times in 41 Posts
Default 302 Ford oil pan
Who makes the best sealing Front sump oil pan for a 302 ford? (67 Mustang) I have a POS made in some other country pan that always leaks no matter what I do. I'm willing to spend good money to fix the problem once and for all.
Old 05-28-2015, 10:40 AM   #2
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Default Re: 302 Ford oil pan
I have the Milodon in the link below on my 68 coupe with a ford Racing 302 block and it is nice and tight. The real trick is to use the best gasket you can find. See the second link.
On my car this is a very tight fit and I have to remove half of the steering linkage to drop the pan.
http://www.summitracing.com/parts/mi...view/make/ford
Dale
Dale Shearon
68 Mustang 6394
Old 05-28-2015, 11:20 AM   #3
RobbieRacer
The pan I have is 7 QTs on it now. I see that is a 5 QT pan. I Wonder if 5 QTs would be enough oil. I have a high volume pump and turn 6500 RPM in the traps.
Old 05-28-2015, 11:30 AM   #4
James Hill
Liked 14 Times in 6 Posts
http://www.charliespans.com/
What we use, not a front sump but he can build pretty much anything.
James Hill is offline   Reply With Quote
Old 05-28-2015, 12:24 PM   #5
Mike Delahanty
Mike Delahanty's Avatar
Liked 276 Times in 54 Posts
With the RPM you want to run and an upgraded oil pump, the 7 quart pan is the smart choice. Ford Racing uses Champ Pans on its 302 based Circle Track engines - and these have beeen tested and proven to be the best available. For the oil pan gasket, the favorite among many engine builders is the Ford Racing 1 piece M-6710-A50.
http://fordperformanceracingparts.co...tKeyField=2990
Old 05-28-2015, 12:42 PM   #6
Chris1529
Liked 70 Times in 29 Posts
I would definitely not use a high volume pump with a 5 QT pan. The front sump configuration would only exacerbate the situation.
Chris Bowman
The Mountain State Mustang
1984 Mustang GT350
Old 05-28-2015, 12:58 PM   #7
Rich67stang
Liked 116 Times in 27 Posts
I use a Moroso 7qt front sump with the kick outs, on both of my SS engines with
no oil problems @ 10k RPM.
Richard Preiser
1613 FGT/I 1510 C/SA 161 F/DA
Rich67stang is offline   Reply With Quote
Old 05-28-2015, 01:57 PM   #8
RobbieRacer
http://www.summitracing.com/parts/mo...view/make/ford
Is this what you are talking about?
