Old 04-26-2015, 07:39 PM   #1
Duster 318
Default Carb. Hesitation
I'm running a 340 with a carter AVS. I was wondering if anyone has ever had trouble with a hesitation on the starting line during acceleration?
Duster 318 is offline   Reply With Quote
Old 04-26-2015, 07:54 PM   #2
Bob Bender
Bob Bender's Avatar
Liked 460 Times in 91 Posts
Default Re: Carb. Hesitation
Check accelerator pump and jetting.
Bob Bender 144 O/SA
Old 04-26-2015, 08:01 PM   #3
Duster 318
I changed the accelerator pump and it helped it. But it still has a slight hesitation?
Old 04-26-2015, 08:05 PM   #4
Ed Wright
Ed Wright's Avatar
Have you tried drilling the squirter holes to something like .035"?
Ed Wright 4156 SS/JA
Old 04-26-2015, 08:39 PM   #5
Duster 318
Haven't done that yet. Might give it a try
Old 04-26-2015, 08:44 PM   #6
Liked 11,002 Times in 2,263 Posts
Look at the air door tension.
Old 04-26-2015, 08:44 PM   #7
George Mirza
Tighten the air valve spring, it needs to be pretty tight on them. Put the accelerator pump rod in the hole that gives the most travel of the pump, I think it's the outer hole.
George Mirza is offline   Reply With Quote
Old 04-26-2015, 09:07 PM   #8
Duster 318
I have the air valve a little loose now. I will give it some more tension. I've got the pump rod in the outer hole it seems to work the best there
