Liked 239 Times in 90 Posts
SBC 350/255 to run 10.70's in G
How much HP or what is the most HP one has made? LOL, I'm bored at work Last edited by jamie2370; 02-02-2015 at 09:23 AM. Reason: Bored!! |
Jamie my guess is it would take about 20 grand lol, hope this helps!
LOL, You are dead on about the money figure
Liked 56 Times in 27 Posts
Jamie / HR9121,
More like $ 13-15K if you have cores ? That's not a cheap combo to build. Good Luck & take your Time , you can still have Fun & Win going 5-6 under !!!
Dave Ribeiro 1033 STK |
Dave, It was a Hypothetical question. I have a 85 camaro with a little 305/263. I hope to make it 5-6 under, LOL.
This is one of my favorite web sites. Ive killed hours playing on it. Everything is pretty much spot on. Except the ".Compute ideal MPH and times at 60', 330', 660' and 1000'. They wont match your cars times for some reason. But they are proportionally correct.
The "ET - MPH - HP Calculators" in the first column. And the 'Gears - Tire - RPM Calculators' at the top of the second column are my favorites. Hope this helps. Steve-o- http://www.wallaceracing.com/Calculators.htm
Steve Tucholsky |
Liked 166 Times in 71 Posts
Basing it off my car (chevelle with 255/280 in h)
Went 11.66 at 3405, with 384 flywheel hp. -140 lbs for to go to safe g weight = an approximate 11.52 so thats about .80 required to go 10.70's at roughly 10hp per tenth like a slide rule calculator, you'd need 450-460hp. Correct me if i'm wrong. And yes my car is a slug, but we're working at it! lol
Chris Chapman 1969 Chevelle NHRA F-G/SA 1090 |
Liked 425 Times in 56 Posts
It's more than just horsepower. Without the right headers, converter, ignition, and carb. Also the car has to leave the starting line hard. Two cars with the same horsepower, will run different times. It's the whole combo and how good one is at making it run. But like has been said on here, bring your wallet.
Gary Parker 1617 STK |
#9 | |
Cooter, looking at Div 2 qualifying history on DRC, You can go to J and be clear and free and I may end up in G. Most of the cars I am avoiding stay in H . There was average around 5 I cars most being 80 under camaros, adkinson is in I and slowest I car was 79 under at most races.
