Liked 6 Times in 3 Posts
I am looking to purchase an engine oil accumulator this winter. Are there other brands available?
Moroso, CVR.....??????? Thank you Ian
They say money can't buy happiness, it can buy race car parts, and that makes me happy Ian Hill GT/FA 1982 Camaro, F/CM 1968 Camaro |
#2 | |
Accusump have always worked well for me!! http://www.accusump.com/
Ross Gregory 5133 Stock,Super Stock 53 Top Dragster |
#3 | |
Liked 373 Times in 129 Posts
I bought a canton and love it, use as a pre-oil @ start and dumps if under 25psi. bought the electric solenoid so it dumps @ startup when I hit the ign. switch.
Liked 39 Times in 10 Posts
Ian, you have a PM.
First one of those I ever saw was just an hyd. cyl
that must have been impressive. so when the oil pressure went down did the cylinder rod extend the front suspenion allowing the oil to run to the back of the pan??? LOL!!!! we may be onto something here call the patent people quick.
more specifically, i am not interested in the accumulator for its pre-oiling capability, although it will be a gained benifit. i will be only requiring a 1 quart accumulator. i am looking for an accumulator with an aluminum barrel and the lightest possible weight. in the hydraulic business we fill the nitrogen portion of the accumulator to 60% of the working pressure. is this the standard for low pressure systems (i.e. our engines oil system pressures of <60psi)? any help is appreciated. worse case i guess i could go buy the cheapest version, read the instructions and then decide if i want to build a light weight unit or not. Regards Ian
