Liked 35 Times in 6 Posts
I am building a 93 formula with an lt1 for pure stock ihra and I am looking for some opinions on Torque converter and rear gear for that combination. As far as the converter, What stall range should I be in? RPM range of the engine is probally only 5500. Advantages, If any, of having the lockup disc in the converter. The transmission is a 4l60. What rear gear is suggested? I was thinking of a 4.10 or 4.56 with 28" tall tires. . Thanks
#2 | |
Liked 184 Times in 113 Posts
Another person is preparing a 93 Camaro on Class Racer. Bullet has a Pure Stock Cam and Spring Package that will pass tech. Even that it is about done by 6000rpm.. I am adding a Yank PT 4200 replacing my Yank SS3800 Converter. Since my car is driven to the meets they are locking converters. 4.65 gearing with 28 inch would work well. Would spend the money to get a complete Moser Rear. The small 7.5 inch rear is ok at stock power levels. Send pictures of your ride and will post it on the PhotoGallery. Dan |
Are you going to be tuning the ecm also? I think I am going to get tuner cats ?
The '93 has a removable chip. You would also need a device programmer, and eraser.
Ed Wright 4156 SS/JA |
I guess the way I am reading the website, It comes as a package with the burner, Tuner program, and everything that is needed.
#6 | |
Also use Byran Herter at PCMforLess. They have a Dyno Facility near Quaker in Ohio and Farmington in North Carolina. May want to ping Ed Wright on the Class Racer D |
Liked 46 Times in 29 Posts
I'd speak to the man Ed Wright who posted above.
He is very knowledgeable from what I have read here. |
They may very well have a package like that.
#9 | |
Rule book is unclear about rear suspension. Are we allowed to replace the lower control arms and the the track locator bar with aftermarket? And What about Frame connectors ? Also the torque arm. I want it off of the rear of the trans. Are we allowed to build a support for that as long as it is part of the trans crossmember? ? I know I saw a 70s camaro with slapper bars at Norwalk a few years ago so I would assume you can use them for Leaf springs. Thanks Aaron
