Liked 165 Times in 51 Posts
Any one here try a MSD PROGRAMMABLE DIGITAL 6
How did it work? Any thing to gain on a stock eliminator car with this? |
Liked 346 Times in 126 Posts
I thought those were not legal for stock, Am I wrong?
Liked 195 Times in 30 Posts
I went from an old early 7-AL to the digital -6 and believe I picked up a little. It has built in start retard and best of all it uses rotating pots to set rev- limiters, both top end and launch so you don't have to mess with all the chips. If I remember correctly it has a lower minimum voltage than the others to function correctly.
Personally I like it and have had several other change over. P.S. The 6 is non programmable which make it legal. Jim |
this is the legal one right
http://www.msdignition.com/Products/...n_Control.aspx And this one is not: http://www.msdignition.com/Products/...ble_6AL-2.aspx Correct? |
I may be out of the loop on this, but from what I remember, the we cannot run the 7531 or any box that has the slew rate controller as it is deemed as traction control. I haven't looked for an updated list lately.
I used to run the Digital 6 Plus and it worked flawlessly - I'm currently putting one in the super stock car once I ever get it finished! Tim
SS/MA 5017 |
