Old 06-11-2012, 10:24 PM   #1
DIV3CR
Liked 3 Times in 1 Post
Default Hoosier tires
When using Hoosier 30.0/9.0-15 slicks l/w radials and run them
tubless do you screw them to the rim?
DIV3CR is offline   Reply With Quote
Old 06-11-2012, 11:18 PM   #2
David Lee
Liked 346 Times in 126 Posts
Default Re: Hoosier tires
I have never
Old 06-12-2012, 12:28 AM   #3
Phillip marvetz
Phillip marvetz's Avatar
Talking Re: Hoosier tires
I do. But just because I bought the wheels used and they already had the holes.
2009 V/SA Record Holder
Old 06-12-2012, 11:35 AM   #4
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: Hoosier tires
I've run them for years on 10" rims at 21 lbs without screws. They may move a bit initially and when I swap them side-to-side the move back a bit. Not enough to worry about and they usually settle down anyway. High HP or low tire pressures may cause issues, but just put a mark on the tire relative to the valve stem and watch for movement.
Old 06-12-2012, 06:32 PM   #5
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
No tubes. No screws here...... 1.38 60' 3500lb
Old 06-12-2012, 08:49 PM   #6
DIV3CR
Thanks guys you have been a great help.
